subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
enclose.
to lib/include.
model
were a number of minor problems which had to be fixed to get it
to compile including modifying the compile rule to handle C++ comments,
changing the syntax of the include statement, and getting rid of "%"
as part of register names.
to RTEMS by Eric Norum. It is freely distributable and was acquired
from the Motorola WWW site. More info is in the FPSP README.
be resolved.
This is current as of sis 2.6.
Derrick Ostertag (ostertag@transition.com).
on the real erc32 hardware.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
