* mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/duart/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/interrupts/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* m68040/fpsp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* m68040/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960ca/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960ka/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960rp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* milli/Makefile.am: Remove AUTOMAKE_OPTIONS.
* semaphore/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cpuModel.h: PR 146.
Adding guards. Remove unnecessary headers.
* shared/interrupts/installisrentries.c: Added support for debug
exception vector.
* shared/interrupts/isr_entries.S: Added support for debug exception
vector.
* mongoosev/include/mongoose-v.h: Added cache constants.
* mongoosev/vectorisrs/vectorisrs.c: More tinkering to improve
performance.
performance.
* mongoosev/vectorisrs/vectorisrs.c: Fixed to use new frame format.
* isr_entries.S: Removed comment incorrectly indicating this
file was cpu_asm.S.
* vectorexceptions.c (mips_dump_exception_frame): New routine
broken out from default exception handler.
* mongoosev/vectorisrs/vectorisrs.c,
shared/interrupts/vectorexceptions.c: Use rtems/bspIo.h, not just
bspIo.h.
* Lots of tinkering and tuning as part of improving interrupt latency
and improving the per-task interrupt level control and FP mask handling.
With these modifications interrupt latency was measured at a worst-case
of 100us, average below 60 us on a 12 Mhz R3000 class CPU with 50
RTEMS tasks in the application.
* mongoosev/README: Updated.
* mongoosev/include/mongoose-v.h: Masks modified.
* mongoosev/vectorisrs/vectorisrs.c: Significant overhaul to address
software prioritization of interrupts. If a higher priority interrupt
occurs while we are looking for new interrupts, we will reinitiate the
scan of all interrupts.
* shared/interrupts/vectorexceptions.c: Removed warning and deleted
blank lines.
* include/Makefile.am: Remove EXTRA_DIST.
* i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h.
* i386/page.c: Include rtems/bspIo.h instead of bspIo.h.
* mongoosev/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* r46xx/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/interrupts/vectorexceptions.c: Include rtems/bspIo.h instead of bspIo.h.
* tx39/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/clock/c_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/mmu/bat.h: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/cpm/brg.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8xx/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/include/cpuIdent.c: Include rtems/bspIo.h instead of bspIo.h.
This was tracked as PR91.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
* ppc403/vectors/vectors.S: Include <bsp.h>.
* shared/include/cpu.h: Remove stray empty lines.
* new_exception_processing/Makefile.in,
new_exception_processing/.cvsignore,
new_exception_processing/Makefile.am,
new_exception_processing/c_isr.inl,
new_exception_processing/cpu.c, new_exception_processing/cpu.h,
new_exception_processing/cpu_asm.S,
old_exception_processing/Makefile.in,
old_exception_processing/.cvsignore,
old_exception_processing/Makefile.am, old_exception_processing/README,
old_exception_processing/TODO, old_exception_processing/c_isr.inl,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/irq_stub.S,
old_exception_processing/ppc_offs.h,
old_exception_processing/ppccache.c, old_exception_processing/rtems.S:
Deleted since now under libbsp.
* configure.ac: Remove old_exception_processing,
new_exception_processing.
* Makefile.am: Ditto.
* .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure.
* configure.ac: Remove mpc750 from new_exception_processing,
Remove mpc604 from new_exception_processing.
* Makefile.am: Preinstall c_isr.inl (HACK).
* ChangeLog: New file.
* configure.ac: Remove ppc603e from old_exception_processing.
* configure.ac: Remove mpc8xx from new_exception_processing.
* support/new_exception_processing/configure.ac,
support/new_exception_processing/rtems/score/c_isr.inl,
support/new_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/configure.ac,
support/old_exception_processing/rtems/score/c_isr.inl,
support/old_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/rtems/score/ppc_offs.h: New files
missed in previous commit.
* configure.ac: Remove mpc8620 from new_exception_processing.
* support/new_exception_processing/Makefile.am,
support/old_exception_processing/Makefile.am,
support/old_exception_processing/cpu_asm.S,
support/old_exception_processing/irq_stub.S: Modified to reflect
old versus new exception processing being a per BSP option.
* support/new_exception_processing/c_isr.inl,
support/new_exception_processing/cpu.h,
support/old_exception_processing/c_isr.inl,
support/old_exception_processing/cpu.h,
support/old_exception_processing/ppc_offs.h: Removed.
* ChangeLog: Corrected spacing.
* new_exception_processing/cpu_asm.S: Support double or single
precision context switches. Note that doing a single precision
context save/restore on a double precision PowerPC machine does not
only result in rounding errors but also screws up the FPSCR register!
* include/Makefile.am: Fix TMPINSTALL_FILES to make automake-1.5
happy.
* include/iosh7045.h: Add SCI0_SMR, SCI1_SMR for sh7032
compatibility to make simsh happy.
process was captured as PR50.
* ppc403/console/console405.c ppc403/tty_drv/.cvsignore,
ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c,
ppc403/tty_drv/tty_drv.h: New files.
* Makefile.am, README, configure.ac, old_exception_processing/cpu.c,
old_exception_processing/cpu.h, ppc403/Makefile.am,
ppc403/clock/clock.c, ppc403/console/Makefile.am,
ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h,
ppc403/timer/timer.c: Modified.
* configure.ac: Delete the commented out line that said that
the mpc8260 used the old exception processing model. This line
also appears to have caused ppc603e to miss this test.
* mpc8xx/timer/timer.c: Added hack for two macros that are not defined
with the new exception processing model:
rtems_cpu_configuration_get_timer_least_valid()
rtems_cpu_configuration_get_timer_average_overhead()
This is captured as PR57.
* .cvsignore: Add more entries.
* include/rtems/score/sh7750_regs.h: Fix definitions of
SH7750_SCBRR1 and SH7750_SCBRR2 so things compile.
* New libcpu support for mcf5206e.
* ChangeLog, clock/ckinit.c, clock/.cvsignore, configure.ac,
console/mcfuart.c, console/.cvsignore, include/mcf5206e.h,
include/mcfmbus.h, include/mcfuart.h, include/.cvsignore,
mbus/mcfmbus.c, mbus/.cvsignore, timer/timer.c, timer/timerisr.S,
timer/.cvsignore, .cvsignore: New files.
* Makefile.am, configure.ac: New libcpu support for mcf5206e.
* include/sh/sh4uart.h, sci/sh4uart.c: Minor fixes post merge.
* mpc8260/clock/.cvsignore, mpc8260/console-generic/.cvsignore,
mpc8260/cpm/.cvsignore, mpc8260/exceptions/.cvsignore,
mpc8260/include/.cvsignore, mpc8260/mmu/.cvsignore,
mpc8260/timer/.cvsignore, mpc8260/.cvsignore: New files.
* mpc8260/exceptions/Makefile.am, mpc8260/include/Makefile.am,
mpc8xx/exceptions/Makefile.am: Updated to autoconf 2.52.
* mpc8260/include/mpc8260.h: "or" is a keyword in C++.
* Makefile.am, README, configure.ac, new_exception_processing/cpu.h,
shared/include/cpu.h, shared/include/cpuIdent.c, shared/src/cache.c:
Added mpc8260 support.
* Added mpc8260 directory.
* Modified Makefile.am and configure.in to build the contents
* mpc8260/Makefile.am, mpc8260/README, mpc8260/clock/Makefile.am,
mpc8260/clock/clock.c, mpc8260/console-generic/Makefile.am,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/.cvsignore,
mpc8260/cpm/Makefile.am, mpc8260/cpm/brg.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/exceptions/.cvsignore,
mpc8260/exceptions/Makefile.am, mpc8260/exceptions/asm_utils.S,
mpc8260/exceptions/raw_exception.c, mpc8260/exceptions/raw_exception.h,
mpc8260/include/Makefile.am, mpc8260/include/console.h,
mpc8260/include/cpm.h, mpc8260/include/mmu.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/Makefile.am, mpc8260/mmu/mmu.c,
mpc8260/timer/Makefile.am, mpc8260/timer/timer.c: New files.
* include/sh4uart.h: move to include/sh/sh4uart.h.
* include/ispsh7750.h: move to include/rtems/score/ispsh7750.h.
* include/iosh7750.h: move include/rtems/score/iosh7750.h.
* include/sh7750_regs.h: move to include/rtems/score/sh7750_regs.h.
* include/rtems/score/ipl.h: move to include/rtems/score/ipl.h.
* include/rtems/score/sh4_regs.h: Reintroduce from Alexandra
Kossovsky's original sources.
* include/Makefile.am: reflect changes above, remove EXTRA_DIST,
require automake 1.5.
* sci/Makefile.am: Disable compilation of console.c.
* sci/sh4uart.c: include <sh/sh4uart.h>, add SH7750_SCSMR_CHK_S,
remove SH4_CPU_HZ_Frequency;
* score/isph7750.c: Remove #if !defined(sh7750), include sh4_regs.h.
