* Index: m68040/Makefile.am, mcf5206/Makefile.am, shared/Makefile.am:
Don't include lib.am.
* mpc505/Makefile.am, mpc6xx/Makefile.am, mpc8260/Makefile.am,
mpc8xx/Makefile.am, ppc403/Makefile.am: Don't include .../lib.am.
* Makefile.am: Don't include .../lib.am.
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am: Don't
include .../lib.am.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am: Don't
include .../lib.am.
* mongoosev/Makefile.am, r46xx/Makefile.am, tx39/Makefile.am:
Don't include .../lib.am. Remove ACLOCAL_AMFLAGS.
* shared/Makefile.am: Don't include .../lib.am.
* wrapup/Makefile.am: Remove.
* configure.ac: Remove wrapup.
* shared/Makefile.am: Use automake compilation rules.
Build *.rels.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Use automake compilation rules.
* mcf5206/Makefile.am: Rename console.rel to mcfuart.rel.
* ChangeLog: Merge-in mcf5206/ChangeLog.
* mcf5206/ChangeLog: Remove.
* ChangeLog: Merge-in sh7032/ChangeLog, sh7045/ChangeLog,
sh7750/ChangeLog.
* sh7032/ChangeLog, sh7045/ChangeLog, sh7750/ChangeLog: Remove.
PR 557/bsps
* cpu.c: Removed. File appears to have been orphaned around June 2000
* configure.ac: Require automake >= 1.8.2.
* Makefile.am, mpc505/Makefile.am, mpc6xx/Makefile.am,
mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am,
Add PREINSTALL_DIRS.
* Makefile.am: Split the blob of *.o into cache.rel, page.rel and
score.rel. Add PREINSTALL_DIRS.
* page.c, cpuModel.S: Remove stray blanks.
Add AM_PROG_CC_C_O. Add subdir-objects to AUTOMAKE_OPTIONS.
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
* clock/Makefile.am, timer/Makefile.am: Remove.
* r46xx/Makefile.am: Built timer.rel, clock.rel.
* Makefile.am: Remove timer, clock.
* tx39/Makefile.am, mongoosev/Makefile.am, shared/Makefile.am:
* configure.ac: Reflect removing clock/Makefile.am,
timer/Makefile.am.
* Makefile.am: Unconditionally build subdirs sh7032, sh7045, sh7750.
* configure.ac: Merge-in sh7032/configure.ac, sh7045/configure.ac,
sh7750/configure.ac.
Add AM_CONDITIONALS sh7032, sh7045, sh7750.
Reflect changes above. Add PREINSTALL_DIRS.
* sh7032/configure.ac, sh7045/configure.ac, sh7750/configure.ac:
Remove.
* sh7032/.cvsignore, sh7045/.cvsignore, sh7750/.cvsignore:
* Makefile.am: Convert to automake compilation rules.
* configure.ac: Remove.
* .cvsignore: Reflect changes above.
* m68040/Makefile.am: Merge-in m68040/fpsp/Makefile.am.
Use automake-compilation rules.
* m68040/fpsp/Makefile.am: Remove.
* Makefile.am: Reflect changes above. Remove CPU_SUBDIR.
Remove CHECK_CUSTOM_BSP.
* clock/Makefile.am: Convert to using automake compilation rules.
* mongoosev/Makefile.am: Ditto.
* r46xx/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* tx39/Makefile.am: Ditto.
* Makefile.am: Remove conditional subdirs.
* configure.ac: Add subdir-object to AUTOMAKE_OPTIONS.
Require automake-1.8.2. Add AM_PROG_CC_C_O.
* syscall/Makefile.am: Remove.
* reg_win/Makefile.am: Remove.
* cache/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.ams above. Use automake compilation
rules.
* configure.ac: Require automake 1.8.2.
Add AM_PROG_CC_C_0.
* cache/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* mpc505/Makefile.am: Ditto.
* mpc6xx/Makefile.am: Ditto.
* mpc8260/Makefile.am: Ditto.
* mpc8xx/Makefile.am: Ditto.
* ppc403/Makefile.am: Ditto.
* mongoosev/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* shared/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* mpc6xx/Makefile.am: Remove libcpuspec.a (Unused).
* mpc505/Makefile.am: Fix typo vectors/vectors.S.
* shared/Makefile.am: Fix typo
EXTRA_DIST = $(libcpuspec_C_FILES)
* mips64orion/.cvsignore, mips64orion/ChangeLog,
mips64orion/Makefile.am, mips64orion/configure.ac,
mips64orion/clock/.cvsignore, mips64orion/clock/Makefile.am,
mips64orion/clock/ckinit.c, mips64orion/clock/clock.S,
mips64orion/clock/clock.h, mips64orion/timer/.cvsignore,
mips64orion/timer/Makefile.am, mips64orion/timer/gettime.S,
mips64orion/timer/timer.c: Removed.
* ppc403/Makefile.am: Fix typo in vectors' compilation rule.
* shared/Makefile.am: Use $(top_srcdir)/../shared instead of
relative subdirs.
* shared/Makefile.am: Fix typo in rule to build from cache/%.c.
* mpc6xx/wrapup/.cvsignore: Remove.
* mongoosev/duart/Makefile.am: Remove.
* mongoosev/vectorisrs/Makefile.am: Remove.
* mongoosev/Makefile.am: Merge-in vectorisrs/Makefile.am,
duart/Makefile.am.
* r46xx/vectorisrs/Makefile.am: Remove.
* r46xx/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/cache/Makefile.am: Remove.
* shared/interrupts/Makefile.am: Remove.
* shared/Makefile.am: Merge-in cache/Makefile.am,
interrupts/Makefile.am.
* tx39/vectorisrs/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/misc/Makefile.am: Remove.
* shared/Makefile.am: Merge-in the Makefile.ams above.
Eliminate VPATH.
* cache/Makefile.am: Eliminate VPATH.
* Makefile.am: Eliminate VPATH.
* ppc403/clock/Makefile.am: Remove.
* ppc403/console/Makefile.am: Remove.
* ppc403/ictrl/Makefile.am: Remove.
* ppc403/timer/Makefile.am: Remove.
* ppc403/tty_drv/Makefile.am: Remove.
* ppc403/vectors/Makefile.am: Remove.
* ppc403/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to ppc403/Makefile.ams.
* mpc505/ictrl/Makefile.am: Remove.
* mpc505/timer/Makefile.am: Remove.
* mpc505/vectors/Makefile.am: Remove.
* mpc505/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to mpc8xx/Makefile.ams.
* mpc8xx/clock/Makefile.am: Remove.
* mpc8xx/console-generic/Makefile.am: Remove.
* mpc8xx/cpm/Makefile.am: Remove.
* mpc8xx/exceptions/Makefile.am: Remove.
* mpc8xx/mmu/Makefile.am: Remove.
* mpc8xx/timer/Makefile.am: Remove.
* mpc8xx/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Remove mpc6xx/*/Makefile, mpc8260/*/Makefile.
* mpc6xx/clock/Makefile.am: Remove.
* mpc6xx/exceptions/Makefile.am: Remove.
* mpc6xx/mmu/Makefile.am: Remove.
* mpc6xx/timer/Makefile.am: Remove.
* mpc6xx/wrapup/Makefile.am: Remove.
* mpc6xx/Makefile.am: Merge-in Makefile.ams above.
* mpc8260/clock/Makefile.am: Remove.
* mpc8260/console-generic/Makefile.am: Remove.
* mpc8260/cpm/Makefile.am: Remove.
* mpc8260/exceptions/Makefile.am: Remove.
* mpc8260/mmu/Makefile.am: Remove.
* mpc8260/timer/Makefile.am: Remove.
* mpc8260/Makefile.am: Merge-in Makefile.ams above.
