PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* include/Makefile.am: Removed.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* delay/Makefile.am: Removed.
* tx39/vectorisrs/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* r46xx/vectorisrs/Makefile.am: Ditto.
* mongoosev/vectorisrs/Makefile.am: Ditto.
* mongoosev/duart/Makefile.am: Ditto.
* shared/interrupts/Makefile.am: Ditto.
* shared/cache/Makefile.am: Ditto. Eliminate *_O_FILES.
* timer/Makefile.am: Ditto.
* clock/Makefile.am: Eliminate *_O_FILES.
* m68040/fpsp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/misc/Makefile.am: Ditto.
* console/Makefile.am: Likewise.
* mbus/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* sci/Makefile.am: Apply 2002-12-14 patch (Apparently dropped by CVS).
* score/Makefile.am: Likewise.
* clock/Makefile.am: Eliminate @RTEMS_BSP@.cfg, $(OBJS).
* sci/Makefile.am: Likewise.
* mbus/mcfmbus.c: Per PR323, move the mbus_send command on line 232
to after the state has been set.
* configure.ac: Remove RTEMS_CHEC_CUSTOM_BSP.
* mpc505/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/console/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/tty_drv/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/include/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/src/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: RTEMS_CHECK_CUSTOM_BSP.
* milli/Makefile.am: Ditto.
* semaphore/Makefile.am: Ditto.
* milli/milli.S: Per PR329, use GNU binutils assembler directives.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* configure.ac: Apply 2002-11-07 patch (Apparently dropped by CVS).
* delay/Makefile.am: Ditto.
* mpc8260/Makefile.am: Merge-in mpc8260/include/Makefile.am.
* mpc8xx/Makefile.am: Merge-in mpc8xx/include/Makefile.am.
* mpc8260/include/Makefile.am: Remove.
* mpc8xx/include/Makefile.am: Remove.
* configure.ac: Remove mpc8260/include/Makefile.
Remove mpc8xx/include/Makefile.
* shared/soft_reset_asm.S: Removed.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Merge in include/Makefile.am.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* sh7045/score/ispsh7045.c: Fixed typos.
* sh7045/score/cpu_asm.c: Fixed typo.
* delay/delay.c, score/ispsh7032.c: Removed warnings.
* score/cpu_asm.c, score/ispsh7750.c: Removed warnings.
* score/cpu_asm.c, score/ispsh7045.c: Removed warnings.
* mpc8xx/console-generic/console-generic.c, mpc8xx/cpm/dpram.c,
mpc8xx/exceptions/raw_exception.c, ppc403/clock/clock.c:
Removed warnings.
* shared/interrupts/installisrentries.c,
shared/interrupts/vectorexceptions.c: Removed warnings.
* cpu.c: Currently only the mpc8260 BSP supports interrupt nesting.
NOTE: These needs to be generalized as the patch is applied to other
BSPs.
* mpc6xx/clock/c_clock.c, mpc6xx/exceptions/raw_exception.c,
mpc6xx/mmu/bat.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to
eliminate warning.
* configure.ac: Remove duplicate mpc6xx/timer/Makefile from CONFIG_FILES.
* configure.ac: Remove duplicate timer/Makefile from CONFIG_FILES.
* mpc8260/exceptions/raw_exception.c: #include <string.h>.
#include <bspIo.h>.
