* | powerpc: Add r2 to CPU context | Sebastian Huber | 2013-11-18 | 2 | -1/+7 |
| | | | | The r2 may be used for thread-local storage. | ||||
* | bsps/arm: ARMV7_MMU_DATA_READ_WRITE_SHAREABLE | Sebastian Huber | 2013-10-27 | 1 | -5/+9 |
| | | | | | Delete ARMV7_MMU_DATA_READ_WRITE_SHAREABLE and move RTEMS_SMP specific MMU attribute settings to arm-cp15.h. | ||||
* | Add a new necessary definition needed for raspberrypi MMU support | Hesham AL-Matary | 2013-10-03 | 1 | -0/+21 |
| | | | | | | | | | | | The new ARM_CP15_CTRL_XP is necessary to share ARMv6 and ARMv7 page-table formats and definitions. It enables the extended page tables (introduced in ARMv6) to be configured for the hardware page translation mechanism. This way we can share ARMv6 and ARMv7 page tables entry formats. Other Fault Status Register Definitions can be useful for debugging or excpetion handlers. | ||||
* | libcpu/sparc/.../access_le.c: Add include file to fix warning | Joel Sherrill | 2013-09-23 | 1 | -0/+1 |
* | bsps: Fix cache manager support | Sebastian Huber | 2013-09-10 | 3 | -0/+12 |
* | bsps/arm: Fix ARM CP15 opcode for get functions | Sebastian Huber | 2013-09-05 | 1 | -3/+3 |
* | sapi: SMP support for chains | Sebastian Huber | 2013-08-30 | 1 | -1/+1 |
| | | | | | | | | Add ISR lock to chain control for proper SMP protection. Replace rtems_chain_extract() with rtems_chain_explicit_extract() and rtems_chain_insert() with rtems_chain_explicit_insert() on SMP configurations. Use rtems_chain_explicit_extract() and rtems_chain_explicit_insert() to provide SMP support. | ||||
* | bsp/xilinx-zynq: Add cache support | Ric Claus | 2013-08-26 | 1 | -1/+18 |
* | bsps/arm: Add more CP15 cache functions | Ric Claus | 2013-08-22 | 1 | -0/+65 |
* | bsps: Fix clock driver defines | Sebastian Huber | 2013-08-14 | 2 | -3/+3 |
* | bsps/powerpc: Per-CPU thread dispatch disable | Sebastian Huber | 2013-08-09 | 3 | -53/+45 |
| | | | | Interrupt support for per-CPU thread dispatch disable level. | ||||
* | score: Per-CPU thread dispatch disable level | Sebastian Huber | 2013-08-09 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Use a per-CPU thread dispatch disable level. So instead of one global thread dispatch disable level we have now one instance per processor. This is a major performance improvement for SMP. On non-SMP configurations this may simplifiy the interrupt entry/exit code. The giant lock is still present, but it is now decoupled from the thread dispatching in _Thread_Dispatch(), _Thread_Handler(), _Thread_Restart_self() and the interrupt entry/exit. Access to the giant lock is now available via _Giant_Acquire() and _Giant_Release(). The giant lock is still implicitly acquired via _Thread_Dispatch_decrement_disable_level(). The giant lock is only acquired for high-level operations in interrupt handlers (e.g. release of a semaphore, sending of an event). As a side-effect this change fixes the lost thread dispatch necessary indication bug in _Thread_Dispatch(). A per-CPU thread dispatch disable level greatly simplifies the SMP support for the interrupt entry/exit code since no spin locks have to be acquired in this area. It is only necessary to get the current processor index and use this to calculate the address of the own per-CPU control. This reduces the interrupt latency considerably. All elements for the interrupt entry/exit code are now part of the Per_CPU_Control structure: thread dispatch disable level, ISR nest level and thread dispatch necessary. Nothing else is required (except CPU port specific stuff like on SPARC). | ||||
* | bsp/csb336: implement bsp_interrupt_vector_enable/disable. | Pavel Pisa | 2013-08-09 | 1 | -0/+10 |
| | | | | Signed-off-by: Pavel Pisa <ppisa@pikron.com> | ||||
* | score: Rename tod.h to todimpl.h | Sebastian Huber | 2013-08-01 | 1 | -1/+1 |
* | bsp/csb336: mc9328mxl correct AITC access in bsp_interrupt_dispatch. | Pavel Pisa | 2013-07-26 | 1 | -1/+2 |
| | | | | | | | | | | | The original version is missing void and result is that (*x >> 16) is optimized to ldh rX,[rY]. But it is not allowed/supported to access bus/address range used by AITC by other than 32 bit wide accesses and 16-bit access results in the data abort exception. The corrected version works on real hardware and is even more readable. Signed-off-by: Pavel Pisa <ppisa@pikron.com> | ||||
* | score: Merge tod implementation into one file | Sebastian Huber | 2013-07-26 | 1 | -0/+1 |
| | | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS(). | ||||
* | Include missing <rtems/score/threaddispatch.h> | Sebastian Huber | 2013-07-26 | 6 | -8/+11 |
* | bsp/mpc55xx: Fix prototype | Peter Dufault | 2013-07-24 | 1 | -1/+1 |
* | score: Merge sysstate API into one file | Sebastian Huber | 2013-07-24 | 1 | -0/+1 |
* | bsp/mpc55xx: Add MPC5668G support | Sebastian Huber | 2013-07-15 | 7 | -13/+6770 |
* | bsps/powerpc: Add ppc_count_leading_zeros() | Sebastian Huber | 2013-07-09 | 1 | -0/+13 |
* | powerpc: Fix Altivec support | Sebastian Huber | 2013-06-26 | 1 | -1/+1 |
| | | | | Use the right context. | ||||
* | termios: Update due to API changes | Sebastian Huber | 2013-06-25 | 9 | -60/+58 |
| | | | | | Termios notifies now the driver about an inactive transmit with the length argument set to zero. | ||||
* | bsps/powerpc: Delete clock_4xx.c | Sebastian Huber | 2013-06-24 | 1 | -225/+0 |
* | bsps: Move bsp_generic_fatal_code to new file | Sebastian Huber | 2013-06-21 | 1 | -5/+2 |
| | | | | Add bsp_generic_fatal(). | ||||
* | bsps/powerpc: Delete bsp_exceptions_in_RAM | Sebastian Huber | 2013-06-21 | 4 | -68/+77 |
| | | | | | Delete ppc_exc_vector_base. Add and use ppc_exc_initialize_with_vector_base(). | ||||
* | bsps/arm: Set vector base address if necessary | Sebastian Huber | 2013-06-20 | 1 | -0/+47 |
* | score: Add and use _Thread_Dispatch_is_enabled() | Sebastian Huber | 2013-06-14 | 4 | -4/+4 |
| | | | | | Delete _Thread_Dispatch_in_critical_section() and _Thread_Is_dispatching_enabled(). | ||||
* | smp: Fix PowerPC context switch | Sebastian Huber | 2013-06-07 | 1 | -1/+1 |
* | bsps/arm: Add SMP support | Sebastian Huber | 2013-05-31 | 1 | -0/+57 |
* | smp: Add PowerPC support | Sebastian Huber | 2013-05-31 | 1 | -0/+23 |
* | score: Remove idle field of Per_CPU_Control | Sebastian Huber | 2013-05-31 | 2 | -4/+10 |
| | | | | | | This field is unused except for special case simulator clock drivers. In these places use an alternative. Add and use _Thread_Set_global_exit_status() and _Thread_Get_global_exit_status(). | ||||
* | bsps/arm: Use Write-Allocate cache for ARMv7 | Sebastian Huber | 2013-05-31 | 1 | -2/+2 |
* | bsps/arm: Merge ARMv7 MMU section definitions | Sebastian Huber | 2013-05-31 | 1 | -0/+43 |
* | bsps/arm: Remove superfluous parameter | Sebastian Huber | 2013-05-06 | 1 | -2/+1 |
* | bsps/arm: Support ARMv7 VMSA sections and control | Sebastian Huber | 2013-05-03 | 1 | -4/+29 |
* | bsps/arm: Add arm_cp15_set_exception_handler() | Sebastian Huber | 2013-05-03 | 1 | -0/+6 |
* | bsps/arm: Add arm_cp15_set_trans*_table_entries() | Sebastian Huber | 2013-05-03 | 1 | -0/+11 |
* | bsps/arm: Add arm_cp15_mmu_disable() | Sebastian Huber | 2013-05-03 | 1 | -0/+46 |
* | bsps/arm: Add arm_cp15_get_min_cache_line_size() | Sebastian Huber | 2013-05-03 | 1 | -6/+26 |
* | bsp/mpc55xx: Avoid empty enum | Sebastian Huber | 2013-04-29 | 1 | -0/+2 |
* | bsp/mpc55xx: Add MMU tag translate initializer | Sebastian Huber | 2013-04-25 | 1 | -3/+6 |
* | D-cache clean&&invalidate for Tiny6410 | Peng Fan | 2013-04-17 | 1 | -0/+21 |
* | bsp/mpc55xx: Typo | Sebastian Huber | 2013-04-17 | 1 | -1/+1 |
* | bsp/mpc55xx: eDMA API changes | Sebastian Huber | 2013-04-08 | 4 | -165/+471 |
* | bsp/mpc55xx: Add alternative register layout | Sebastian Huber | 2013-04-08 | 1 | -0/+17 |
* | bsp/mpc55xx: Add PCR index enumeration | Sebastian Huber | 2013-04-08 | 1 | -2/+266 |
* | bsp/mpc55xx: New fatal errors | Sebastian Huber | 2013-04-08 | 1 | -4/+3 |
* | bsps: Fix warnings | Sebastian Huber | 2013-04-08 | 1 | -1/+1 |
* | mpc83xx: Add and use mpc83xx_reset() | Sebastian Huber | 2013-03-14 | 1 | -0/+19 |
| | | | | | The inline version makes it possible to use this code in different memory areas. |
