path: root/c/src/lib/libcpu (follow)
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-043-2/+7
| | | | | * i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h. * i386/page.c: Include rtems/bspIo.h instead of bspIo.h.
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-045-4/+11
| | | | | | | * mongoosev/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h. * r46xx/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h. * shared/interrupts/vectorexceptions.c: Include rtems/bspIo.h instead of bspIo.h. * tx39/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-047-6/+15
| | | | | | | | | * mpc6xx/clock/c_clock.c: Include rtems/bspIo.h instead of bspIo.h. * mpc6xx/mmu/bat.h: Include rtems/bspIo.h instead of bspIo.h. * mpc8260/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h. * mpc8260/cpm/brg.c: Include rtems/bspIo.h instead of bspIo.h. * mpc8xx/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h. * shared/include/cpuIdent.c: Include rtems/bspIo.h instead of bspIo.h.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-284-1/+50
| | | | | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. * rtems/score/c_isr.inl: Deleted and contents merged into cpu.c. * cpu.c: Received contents of c_isr.inl. * Makefile.am: Deleted reference to c_isr.inl.
* 2001-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-283-7/+6
| | | | | * ppc403/vectors/vectors.S: Include <bsp.h>. * shared/include/cpu.h: Remove stray empty lines.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-2719-5067/+18
| | | | | | | | | | | | | | | | | | * new_exception_processing/Makefile.in, new_exception_processing/.cvsignore, new_exception_processing/Makefile.am, new_exception_processing/c_isr.inl, new_exception_processing/cpu.c, new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S, old_exception_processing/Makefile.in, old_exception_processing/.cvsignore, old_exception_processing/Makefile.am, old_exception_processing/README, old_exception_processing/TODO, old_exception_processing/c_isr.inl, old_exception_processing/cpu.c, old_exception_processing/cpu.h, old_exception_processing/cpu_asm.S, old_exception_processing/irq_stub.S, old_exception_processing/ppc_offs.h, old_exception_processing/ppccache.c, old_exception_processing/rtems.S: Deleted since now under libbsp.
* 2001-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-273-25/+7
| | | | | | * configure.ac: Remove old_exception_processing, new_exception_processing. * Makefile.am: Ditto.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-272-0/+8
| | | | * .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-212-4/+6
| | | | | * configure.ac: Remove mpc750 from new_exception_processing, Remove mpc604 from new_exception_processing.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-212-0/+10
| | | | | * Makefile.am: Preinstall c_isr.inl (HACK). * ChangeLog: New file.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-212-2/+5
| | | | * configure.ac: Remove ppc603e from old_exception_processing.
* 2001-11-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-202-1/+4
| | | | * configure.ac: Remove mpc8xx from new_exception_processing.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-201-0/+166
| | | | | | | | | | | * support/new_exception_processing/configure.ac, support/new_exception_processing/rtems/score/c_isr.inl, support/new_exception_processing/rtems/score/cpu.h, support/old_exception_processing/configure.ac, support/old_exception_processing/rtems/score/c_isr.inl, support/old_exception_processing/rtems/score/cpu.h, support/old_exception_processing/rtems/score/ppc_offs.h: New files missed in previous commit.
| | | | * configure.ac: Remove mpc8620 from new_exception_processing.
* 2001-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-202-1/+11
| | | | | | | | | | | | | * support/new_exception_processing/Makefile.am, support/old_exception_processing/Makefile.am, support/old_exception_processing/cpu_asm.S, support/old_exception_processing/irq_stub.S: Modified to reflect old versus new exception processing being a per BSP option. * support/new_exception_processing/c_isr.inl, support/new_exception_processing/cpu.h, support/old_exception_processing/c_isr.inl, support/old_exception_processing/cpu.h, support/old_exception_processing/ppc_offs.h: Removed.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-201-1/+4
| | | | * ChangeLog: Corrected spacing.
* 2001-11-14 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2001-11-143-196/+224
| | | | | | | * new_exception_processing/cpu_asm.S: Support double or single precision context switches. Note that doing a single precision context save/restore on a double precision PowerPC machine does not only result in rounding errors but also screws up the FPSCR register!
* 2001-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-142-1/+6
| | | | | * include/Makefile.am: Fix TMPINSTALL_FILES to make automake-1.5 happy.
* 2001-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-142-0/+9
| | | | | * include/iosh7045.h: Add SCI0_SMR, SCI1_SMR for sh7032 compatibility to make simsh happy.
* 2001-11-08 Dennis Ehlin (ECS) <Dennis.Ehlin@ecs.ericsson.se>Joel Sherrill2001-11-0919-29/+1378
| | | | | | | | | | | | | | | | This modification is part of the submitted modifications necessary to support the IBM PPC405 family. This submission was reviewed by Thomas Doerfler <Thomas.Doerfler@imd-systems.de> who ensured it did not negatively impact the ppc403 BSPs. The submission and tracking process was captured as PR50. * ppc403/console/console405.c ppc403/tty_drv/.cvsignore, ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c, ppc403/tty_drv/tty_drv.h: New files. * Makefile.am, README, configure.ac, old_exception_processing/cpu.c, old_exception_processing/cpu.h, ppc403/Makefile.am, ppc403/clock/clock.c, ppc403/console/Makefile.am, ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h, ppc403/timer/timer.c: Modified.
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-072-1/+6
| | | | | | * configure.ac: Delete the commented out line that said that the mpc8260 used the old exception processing model. This line also appears to have caused ppc603e to miss this test.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-292-0/+18
| | | | | | | | * mpc8xx/timer/timer.c: Added hack for two macros that are not defined with the new exception processing model: rtems_cpu_configuration_get_timer_least_valid() rtems_cpu_configuration_get_timer_average_overhead() This is captured as PR57.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-292-0/+17
| | | | * .cvsignore: Add more entries.
* 2001-10-28 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-282-2/+8
| | | | | * include/rtems/score/sh7750_regs.h: Fix definitions of SH7750_SCBRR1 and SH7750_SCBRR2 so things compile.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-266-0/+168
| | | | | | | | | * New libcpu support for mcf5206e. * ChangeLog, clock/ckinit.c, clock/.cvsignore, configure.ac, console/mcfuart.c, console/.cvsignore, include/mcf5206e.h, include/mcfmbus.h, include/mcfuart.h, include/.cvsignore, mbus/mcfmbus.c, mbus/.cvsignore, timer/timer.c, timer/timerisr.S, timer/.cvsignore, .cvsignore: New files.
* 2001-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-263-0/+15
| | | | * Makefile.am, configure.ac: New libcpu support for mcf5206e.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-2616-0/+2541
* 2001-10-26 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-263-12/+16
| | | | * include/sh/sh4uart.h, sci/sh4uart.c: Minor fixes post merge.
* 2001-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-257-0/+19
| | | | | | | * mpc8260/clock/.cvsignore, mpc8260/console-generic/.cvsignore, mpc8260/cpm/.cvsignore, mpc8260/exceptions/.cvsignore, mpc8260/include/.cvsignore, mpc8260/mmu/.cvsignore, mpc8260/timer/.cvsignore, mpc8260/.cvsignore: New files.
* 2001-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-244-11/+18
| | | | | * mpc8260/exceptions/Makefile.am, mpc8260/include/Makefile.am, mpc8xx/exceptions/Makefile.am: Updated to autoconf 2.52.
* 2001-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-242-1/+5
| | | | * mpc8260/include/mpc8260.h: "or" is a keyword in C++.
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-228-4/+44
| | | | | | * Makefile.am, README, configure.ac, new_exception_processing/cpu.h, shared/include/cpu.h, shared/include/cpuIdent.c, shared/src/cache.c: Added mpc8260 support.
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-2226-0/+4409
| | | | | | | | | | | | | | | | * Added mpc8260 directory. * Modified Makefile.am and configure.in to build the contents * mpc8260/Makefile.am, mpc8260/README, mpc8260/clock/Makefile.am, mpc8260/clock/clock.c, mpc8260/console-generic/Makefile.am, mpc8260/console-generic/console-generic.c, mpc8260/cpm/.cvsignore, mpc8260/cpm/Makefile.am, mpc8260/cpm/brg.c, mpc8260/cpm/cp.c, mpc8260/cpm/dpram.c, mpc8260/exceptions/.cvsignore, mpc8260/exceptions/Makefile.am, mpc8260/exceptions/asm_utils.S, mpc8260/exceptions/raw_exception.c, mpc8260/exceptions/raw_exception.h, mpc8260/include/Makefile.am, mpc8260/include/console.h, mpc8260/include/cpm.h, mpc8260/include/mmu.h, mpc8260/include/mpc8260.h, mpc8260/mmu/Makefile.am, mpc8260/mmu/mmu.c, mpc8260/timer/Makefile.am, mpc8260/timer/timer.c: New files.
* 2001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-151-0/+179
| | | | | | | | | | | | | | | | * include/sh4uart.h: move to include/sh/sh4uart.h. * include/ispsh7750.h: move to include/rtems/score/ispsh7750.h. * include/iosh7750.h: move include/rtems/score/iosh7750.h. * include/sh7750_regs.h: move to include/rtems/score/sh7750_regs.h. * include/rtems/score/ipl.h: move to include/rtems/score/ipl.h. * include/rtems/score/sh4_regs.h: Reintroduce from Alexandra Kossovsky's original sources. * include/Makefile.am: reflect changes above, remove EXTRA_DIST, require automake 1.5. * sci/Makefile.am: Disable compilation of console.c. * sci/sh4uart.c: include <sh/sh4uart.h>, add SH7750_SCSMR_CHK_S, remove SH4_CPU_HZ_Frequency; * score/isph7750.c: Remove #if !defined(sh7750), include sh4_regs.h.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-152-0/+5
| | | | * configure.ac: Add sh7750.
* 2001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1511-205/+99
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1216-15/+9
| | | | | | | | | * mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c, mpc8xx/timer/timer.c, new_exception_processing/cpu.c, new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S, old_exception_processing/cpu.c, old_exception_processing/cpu.h, old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1212-11/+6
| | | | | | | * clock/ckinit.c, delay/delay.c, include/iosh7032.h, include/ispsh7032.h, include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-1211-10/+6
| | | | | | * clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h, include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-129-9/+0
| | | | | | * clock/ckinit.c, include/iosh7750.h, include/ipl.h, include/ispsh7750.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c, score/ispsh7750.c, timer/timer.c: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1214-3/+552
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-123-54/+6
| | | | | | * include/sh4_regs.h: Deleted and contents merged in score/cpu to avoid dependencies. * include/Makefile.am: Reflects above.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1213-538/+0
* 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-1226-0/+4989
| | | | | | | | | | | | | * clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am, include/Makefile.am, include/iosh7750.h, include/ipl.h, include/ispsh7750.h, include/sh4_regs.h, include/sh4uart.h, include/sh7750_regs.h, include/.cvsignore, sci/Makefile.am, sci/console.c, sci/sh4uart.c, sci/.cvsignore, score/Makefile.am, score/cpu_asm.c, score/ispsh7750.c, score/.cvsignore, timer/Makefile.am, timer/timer.c, timer/.cvsignore, configure.ac, .cvsignore, ChangeLog: New files. Reviewed and updated to latest automake and autoconf standards by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1126-1/+92
* 2001-10-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-8/+15
| | | | | * configure.in: AC_PREREQ(2.52), Adapt CONFIG_SUBDIRS to autoconf-2.52.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-103-12/+32
| | | | | | * Makefile.am: reformat noinst_HEADERS to work around a bug in automake-1.4-p5. * configure.in: autoupdate to autoconf-2.52, apply RTEMS_CPU_SUBDIRS.
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-283-4/+11
| | | | | | | * old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay(). Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles(). * shared/include/cpu.h: Renamed delay() to rtems_bsp_delay(). Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* 2001-09-27 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill2001-09-271-0/+6
| | | | | | * cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The bug has been there all the time, but only hits the leon bsp since the leon cpu has a 5-stage pipeline (erc32 has 4 stages).
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-273-3/+9
| | | | | | * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * cache/Makefile.am: Use 'PREINSTALL_FILES ='. * cache/Makefile.am: Use 'CLEANFILES ='.
