* mpc8xx/console-generic/console-generic.c: Avoid use of
BSP definitions and rely on the new routine
mbx8xx_console_get_configuration() to get information. This
routine was formerly incorrectly called
mbx8xx_console_use_maximum_buffer_size().
binding to the exception code.
* configure.in, Makefile.am: Explicitly specify whether an
RTEMS_CPU_MODEL is using old or new exception processing. This
is important because when building multilib, you do not know
the RTEMS_CPU_MODEL. So everything built in a multilib'ed RTEMS
must be independent of the exception model and allow for late
* page.c: Readd deleted comment lines.
* Added full support for MPC505.
* mpc505/ictrl: New directory.
* configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition.
* mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am,
mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files.
* mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h".
* mpc505/vectors/Makefile.am: alignment exception handler now included.
* mpc505/vectors/vectors.S: Now use constants for exception numbers.
* old_exception_processing/ppc_offs.h: New file.
* old_exception_processing/Makefile.am: Account for ppc_offs.h.
* old_exception_processing/cpu.h: Make Nest and Disable levels volatile.
* old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
* shared/include/cache.h: Improved file header.
* mpc8xx/console-generic/console-generic.c: Removed include of
<bsp.h> by adding BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() which can be hard coded
or check non-volatile memory for configuration.
* mpc8xx/console-generic/console-generic.c: Removed warnings.
* mpc6xx/clock/c_clock.h: Removed commented out reference to <bsp.h>.
* mpc6xx/timer/timer.c: Ditto.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h: Removed use of
bsp.h and replaced it with use of proper interfaces or explicit
externs of required functions and data.
* page.c: Replaced prototype of printk() with include of <bspIo.h>.
* ChangeLog: Corrected comment.
* clock/ckinit.c: Removed commented out include of bsp.h.
* Makefile.am: Corrected condition CPU model selection so
multilib'ing and bare BSP works.
* idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so
i386 RTEMS can be multilib'ed.
* shared/src/cache_manager.c: Minor bug fix -- changed > to >= so the
last address is invalidated.
* clock/ckinit.c: Removed include of <bsp.h>. Also switch to
macros to get configuration data.
* timer/timer.c: Removed include of <bsp.h>. Fixed comment
that said 4650 (a mips part).
* clock/clock.S: Commented out non-GNU assembly.
* clock/Makefile.am, timer/Makefile.am: Include compile.am
* clock/Makefile.am, milli/Makefile.am, semaphore/Makefile.am,
* Makefile.am: Include compile.am
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am:
Include compile.am
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am: Include
compile.am
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
* clock/Makefile.am, null/Makefile.am, sci/Makefile.am,
timer/Makefile.am, score/Makefile.am: Include compile.am
* clock/Makefile.am, delay/Makefile.am, null/Makefile.am,
sci/Makefile.am, timer/Makefile.am, score/Makefile.am: Include
compile.am
* reg_win/Makefile.am, syscall/Makefile.am: Include compile.am
Add support for configuration parameters in NVRAM
* ChangeLog: File paths corrected.
* console-generic/console-generic.c: Addition of support for shared
printk and no termios.
2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* console-generic/console-generic.c(m8xx_uart_pollWrite):
Flush actual buffer.
* shared/src/cache_manager.c (rtems_cache_flush_multiple_data_lines,
rtems_cache_invalidate_multiple_data_lines): Do not operate on the
entire address space when flushing zero bytes.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
were needed to move exception processing to score/cpu.
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
_Interrupt_Manager_initialization.
