PR 288/rtems
* support/new_exception_processing/cpu.c: _ISR_Nest_level is now
properly maintained and does not reside in SPRG0.
PR 416/bsps
* ppc403/ictrl/ictrl.c (ictrl_isr): We acknolwegde the interrupt in
interrupt controller (clr_exisr(mask)) before calling the interrupt
handler that will acnowledge the interrupt source. This results in
the interrupt beeing seen a second time by the interrupt controller.
Reported and fixed by El Kolli Yacine <yacine.elkolli@crf.canon.fr>.
PR 368/filesystems
* mpc8xx/include/mpc8xx.h: Add PCMCIA registers.
PR 349/bsps
* shared/include/cpuIdent.c: Readd PPC604r CPU.
PR 356/bsps
* cpu.c: This patch makes RTEMS/PowerPC eabi compliant.
PR 349/bsps
* mpc6xx/exceptions/raw_exception.c, mpc6xx/mmu/bat.c,
mpc6xx/mmu/pte121.c, shared/include/cpuIdent.c,
shared/include/cpuIdent.h, shared/src/Makefile.am, shared/src/stack.c,
shared/src/stackTrace.h, powerpc/registers.h:
- undo improper 'fix' who broke mpc604r identification
- fix: 7400 identification PVR value was wrong
- enhance 'setdbat()' to switch OFF a given BAT if called with 0 size
- fix: page table support bugfix
- enhancement: provide routines to take and print stack trace
snapshots
- add definitions for HID1 and DABR SPRs
PR 348/bsps
* mpc6xx/exceptions/raw_exception.c: Add PPC_603ev as required
by MTX603e BSP.
AMD a29k is obsolete.
* Makefile.am: Removed reference.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/configure.ac,
a29k/clock/.cvsignore, a29k/clock/Makefile.am, a29k/clock/ckinit.c,
a29k/clock/clock.S, a29k/clock/clock.h, a29k/timer/.cvsignore,
a29k/timer/Makefile.am, a29k/timer/timer.c, a29k/timer/timerisr.c:
Removed.
* score/cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* include/Makefile.am: Removed.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* delay/Makefile.am: Removed.
* tx39/vectorisrs/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* r46xx/vectorisrs/Makefile.am: Ditto.
* mongoosev/vectorisrs/Makefile.am: Ditto.
* mongoosev/duart/Makefile.am: Ditto.
* shared/interrupts/Makefile.am: Ditto.
* shared/cache/Makefile.am: Ditto. Eliminate *_O_FILES.
* timer/Makefile.am: Ditto.
* clock/Makefile.am: Eliminate *_O_FILES.
* m68040/fpsp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/misc/Makefile.am: Ditto.
* console/Makefile.am: Likewise.
* mbus/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* sci/Makefile.am: Apply 2002-12-14 patch (Apparently dropped by CVS).
* score/Makefile.am: Likewise.
* clock/Makefile.am: Eliminate @RTEMS_BSP@.cfg, $(OBJS).
* sci/Makefile.am: Likewise.
* mbus/mcfmbus.c: Per PR323, move the mbus_send command on line 232
to after the state has been set.
* configure.ac: Remove RTEMS_CHEC_CUSTOM_BSP.
* mpc505/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/console/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/tty_drv/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/include/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/src/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: RTEMS_CHECK_CUSTOM_BSP.
* milli/Makefile.am: Ditto.
* semaphore/Makefile.am: Ditto.
* milli/milli.S: Per PR329, use GNU binutils assembler directives.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* configure.ac: Apply 2002-11-07 patch (Apparently dropped by CVS).
* delay/Makefile.am: Ditto.
* mpc8260/Makefile.am: Merge-in mpc8260/include/Makefile.am.
* mpc8xx/Makefile.am: Merge-in mpc8xx/include/Makefile.am.
* mpc8260/include/Makefile.am: Remove.
* mpc8xx/include/Makefile.am: Remove.
* configure.ac: Remove mpc8260/include/Makefile.
Remove mpc8xx/include/Makefile.
* shared/soft_reset_asm.S: Removed.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Merge in include/Makefile.am.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
