* clock/Makefile.am: Eliminate @RTEMS_BSP@.cfg, $(OBJS).
* sci/Makefile.am: Likewise.
* score/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* mbus/mcfmbus.c: Per PR323, move the mbus_send command on line 232
to after the state has been set.
* configure.ac: Remove RTEMS_CHEC_CUSTOM_BSP.
* mpc505/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/console/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/tty_drv/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/include/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/src/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: RTEMS_CHECK_CUSTOM_BSP.
* milli/Makefile.am: Ditto.
* semaphore/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* milli/milli.S: Per PR329, use GNU binutils assembler directives.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* clock/Makefile.am: Eliminate *_O_FILES.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* configure.ac: Apply 2002-11-07 patch (Apparently dropped by CVS).
* delay/Makefile.am: Ditto.
* mpc8260/Makefile.am: Merge-in mpc8260/include/Makefile.am.
* mpc8xx/Makefile.am: Merge-in mpc8xx/include/Makefile.am.
* mpc8260/include/Makefile.am: Remove.
* mpc8xx/include/Makefile.am: Remove.
* configure.ac: Remove mpc8260/include/Makefile.
Remove mpc8xx/include/Makefile.
* shared/soft_reset_asm.S: Removed.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Merge in include/Makefile.am.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* sh7045/score/ispsh7045.c: Fixed typos.
* sh7045/score/cpu_asm.c: Fixed typo.
* delay/delay.c, score/ispsh7032.c: Removed warnings.
* score/cpu_asm.c, score/ispsh7750.c: Removed warnings.
* score/cpu_asm.c, score/ispsh7045.c: Removed warnings.
* mpc8xx/console-generic/console-generic.c, mpc8xx/cpm/dpram.c,
mpc8xx/exceptions/raw_exception.c, ppc403/clock/clock.c:
Removed warnings.
* shared/interrupts/installisrentries.c,
shared/interrupts/vectorexceptions.c: Removed warnings.
* cpu.c: Currently only the mpc8260 BSP supports interrupt nesting.
NOTE: These needs to be generalized as the patch is applied to other
BSPs.
* mpc6xx/clock/c_clock.c, mpc6xx/exceptions/raw_exception.c,
mpc6xx/mmu/bat.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to
eliminate warning.
* configure.ac: Remove duplicate mpc6xx/timer/Makefile from CONFIG_FILES.
* configure.ac: Remove duplicate timer/Makefile from CONFIG_FILES.
* mpc8260/exceptions/raw_exception.c: #include <string.h>.
#include <bspIo.h>.
* configure.ac, shared/misc/Makefile.am: PR217 required that the
idle task be moved to libcpu so it could be more acutely aware of
the CPU model. This file was modified to pick up the idle task
from there.
* shared/misc/m68kidle.c: New file.
* mpc6xx/wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* m68040/fpsp/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/mbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/misc/Makefile.am: Use .$(OBJEXT) instead of .o.
* milli/Makefile.am: Use .$(OBJEXT) instead of .o.
* semaphore/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/tty_drv/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/include/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/src/Makefile.am: Use .$(OBJEXT) instead of .o.
* mongoosev/duart/Makefile.am: Use .$(OBJEXT) instead of .o.
* mongoosev/vectorisrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* r46xx/vectorisrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/interrupts/Makefile.am: Use .$(OBJEXT) instead of .o.
* tx39/vectorisrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960ca/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960ka/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960rp/Makefile.am: Use .$(OBJEXT) instead of .o.
* sci/Makefile.am: Use .$(OBJEXT) instead of .o.
* score/Makefile.am: Use .$(OBJEXT) instead of .o.
* delay/Makefile.am: Use .$(OBJEXT) instead of .o.
* cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* reg_win/Makefile.am: Use .$(OBJEXT) instead of .o.
* syscall/Makefile.am: Use .$(OBJEXT) instead of .o.
