* syscall/Makefile.am: Remove.
* reg_win/Makefile.am: Remove.
* cache/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.ams above. Use automake compilation
rules.
Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake >= 1.8.2.
* cache/Makefile.am: Remove all-local: $(ARCH).
* reg_win/Makefile.am: Remove all-local: $(ARCH).
* syscall/Makefile.am: Remove all-local: $(ARCH).
* sparc/cache/Makefile.am: Reformat. Use dirstamps for preinstallation.
* sparc/reg_win/Makefile.am: Reformat.
* sparc/syscall/Makefile.am: Reformat.
cache/Makefile.am: Reflect having moved automake.
reg_win/Makefile.am: Reflect having moved automake.
syscall/Makefile.am: Reflect having moved automake.
* cache/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* reg_win/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* syscall/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* reg_win/Makefile.am: Use .$(OBJEXT) instead of .o.
* syscall/Makefile.am: Use .$(OBJEXT) instead of .o.
* cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* reg_win/Makefile.am: Remove AUTOMAKE_OPTIONS.
* syscall/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/Makefile.am, syscall/Makefile.am, cache/Makefile.am:
* cache/.cvsignore: Add cache.h.
* reg_win/Makefile.am, syscall/Makefile.am: Include compile.am
converted to automake.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
