* | SPARC: added libcpu lowlevel access and byteorder routines/definitions | Daniel Hellstrom | 2012-03-21 | 1 | -0/+8 |
| | | | | | | | | | | | | The low level routines can be used in different occasions, it will be required when accessing PCI. Note the difference between byteorder.h (inlined functions) and access.S where the functions will be declared in the library archive librtemscpu.a. Function names starting with _ are in library and can be referenced by function pointers. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 1 | -1/+1 |
| | | | | * preinstall.am: Regenerated. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+22 |
