PR 1249/build
* configure.ac: Jerry Needell <jerry.needell@unh.edu> reported that the
leon3 was left out of the cache enable logic. Thus the cache
management support code was empty on LEON3 CPUs.
* configure.ac: Use RTEMS_AMPOLISH3.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* preinstall.am: New.
* Makefile.am: Include preinstall.am.
* configure.ac: Remove RTEMS_ENABLE_BARE.
* configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP.
* syscall/Makefile.am: Remove.
* reg_win/Makefile.am: Remove.
* cache/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.ams above. Use automake compilation
rules.
Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake >= 1.8.2.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* configure.ac: Add RTEMS_PROG_CCAS.
* tbr/Makefile.am: Remove.
* tbr/.cvsignore: Remove.
* tbr/tbr.c: Remove.
* tbr/tbr.h: Remove.
* configure.ac: Remove tbr subdir.
* Makefile.am: Remove tbr subdir.
* tbr/Makefile.am: New file.
* tbr/.cvsignore: New file.
* tbr/tbr.c: New file.
* tbr/tbr.h: New file.
* configure.ac: Add tbr subdir.
* Makefile.am: Add tbr subdir.
* cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* reg_win/Makefile.am: Remove AUTOMAKE_OPTIONS.
* syscall/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
