Update #3285.
This patch adds NOP instructions to prevent instruction sequences
that are sensitive to the LEON3FT B2BST errata. See GRLIB-TN-0009:
"LEON3FT Stale Cache Entry After Store with Data Tag Parity Error"
for more information.
The sequences are only modified if __FIX_LEON3FT_B2BST is defined.
The patch works in conjunction with the -mfix-ut700, -mfix-gr712rc,
and -mfix-ut699 GCC flags that prevents the sensitive sequences from
being generated.
Update #3057.
- All references of %0 changed to %g0
- 'call label,0' changed to 'call label'. According to the sparc
specification call does not take any registers
- '.seg "text"' changed to '.section ".text"'
- the synonym stub is replaced with stb
- the synonym stuh is replaced with sth
The low level routines can be used in different occasions, it will be
required when accessing PCI.
Note the difference between byteorder.h (inlined functions) and access.S
where the functions will be declared in the library archive librtemscpu.a.
Function names starting with _ are in library and can be referenced by
function pointers.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
