* shared/src/cache_aligned_malloc.c: Added include of <stdlib.h>
to eliminate warnings.
* shared/src/cache_manager.c
(rtems_cache_invalidate_multiple_instruction_lines): If
CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is
an instruction cache but no notion of line size.
* shared/include/cache.h: Improved file header.
* shared/src/cache_manager.c: Minor bug fix -- changed > to >= so the
last address is invalidated.
* shared/src/cache_manager.c (rtems_cache_flush_multiple_data_lines,
rtems_cache_invalidate_multiple_data_lines): Do not operate on the
entire address space when flushing zero bytes.
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
