* | Patch from John Cotton <john.cotton@nrc.ca> to correct cache | Joel Sherrill | 2000-06-14 | 3 | -83/+80 |
| | | | | | | routine naming to follow RTEMS package/object.method rule. This patch also eliminated calls to the obsolete routine m68k_enable_caching. | ||||
* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 3 | -0/+367 |
now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. |
