BSP needs to be eliminated.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
cosmetic things.
Please find enclosed a patch which enables me to build the bare-bsp for
sh-rtems.
1. Add preinstall to libbsp/bare/include/Makefile.in
2. Removed FORCEIT, add preinstall to
libbsp/sh/gensh1/include/Makefile.in
3. Disabled support of set_vector from sh code (shared/setvec.c is still
present but isn't used anymore), set_vector replaced with standard rtems
functions.
Problems still present:
1. Support of spin-delays in bare bsp
2. Proper support of cpu frequency
To configure I used:
<srcdir>/configure \
--target=sh-rtems \
--prefix=<instdir>/sh-bare \
--enable-bare-cpu-cflags='-Wall -m1 -DMHZ=20
-DCPU_CONSOLE_DEVNAME="\"/dev/null\""'
--enable-rtemsbsp=bare \
--disable-networking \
--disable-cxx \
--disable-posix \
--disable-tests
IMO, if there are no objections to this patch, a similar approach should
be applied to all CPUs/BSPs (esp. hppa1.1, mips64orion, ppc403, because
they apply set_vector inside of libcpu).
use a wildcard rule instead of explicit listing all include files
(I have more libcpu header files than the public version has. This patch
removes the need to patch this Makefile for my private bsps)
