1998-12-14 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 4 | -12/+12 | |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | |||||
1998-10-13 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct minor | Joel Sherrill | 1 | -2/+2 | |
cosmetic things. | |||||
1998-09-30 | New file from Ralf. | Joel Sherrill | 1 | -0/+91 | |
1998-09-29 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 3 | -8/+7 | |
Please find enclosed a patch which enables me to build the bare-bsp for sh-rtems. Changes: 1. Add preinstall to libbsp/bare/include/Makefile.in 2. Removed FORCEIT, add preinstall to libbsp/sh/gensh1/include/Makefile.in 3. Disabled support of set_vector from sh code (shared/setvec.c is still present but isn't used anymore), set_vector replaced with standard rtems functions. Problems still present: 1. Support of spin-delays in bare bsp 2. Proper support of cpu frequency To configure I used: <srcdir>/configure \ --target=sh-rtems \ --prefix=<instdir>/sh-bare \ --enable-bare-cpu-model=sh7032 \ --enable-bare-cpu-cflags='-Wall -m1 -DMHZ=20 -DCPU_CONSOLE_DEVNAME="\"/dev/null\""' --enable-rtemsbsp=bare \ --disable-networking \ --disable-cxx \ --disable-posix \ --disable-tests IMO, if there are no objections to this patch, a similar approach should be applied to all CPUs/BSPs (esp. hppa1.1, mips64orion, ppc403, because they apply set_vector inside of libcpu). | |||||
1998-04-27 | Fix from Ralf Corsepius: | Joel Sherrill | 1 | -6/+1 | |
use a wildcard rule instead of explicit listing all include files (I have more libcpu header files than the public version has. This patch removes the need to patch this Makefile for my private bsps) | |||||
1998-03-20 | New port from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 20 | -0/+1546 | |
1998-03-20 | SH port submitted from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 3 | -0/+874 | |
