path: root/c/src/lib/libcpu/sh/sh7750/include/sh (unfollow)
2017-12-08bsp/gensh4: Move libcpu files to BSPSebastian Huber1-174/+0
Update #3254.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2012-05-03libcpu misc m68k and sh - Correct formatting and remove weird Id stringsJoel Sherrill1-10/+6
2008-09-02Convert to using bool.Ralf Corsepius1-4/+4
2004-04-15Remove stray white spaces.Ralf Corsepius1-1/+0
2004-03-312004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-16/+16
* sh7032/clock/ckinit.c, sh7750/include/sh/sh4uart.h, sh7750/sci/sh4uart.c: Cosmetics.
2004-03-312004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-20/+20
* sh7032/clock/ckinit.c, sh7032/delay/delay.c, sh7032/include/ispsh7032.h, sh7032/sci/sci.c, sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/clock/ckinit.c, sh7045/include/ispsh7045.h, sh7045/sci/sci.c, sh7045/sci/sci_termios.c, sh7045/score/cpu_asm.c, sh7045/timer/timer.c, sh7750/clock/ckinit.c, sh7750/include/rtems/score/ispsh7750.h, sh7750/include/sh/sh4uart.h, sh7750/sci/sh4uart.c, sh7750/score/cpu_asm.c, sh7750/score/ispsh7750.c, sh7750/timer/timer.c: Convert to using c99 fixed size types.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* clock/ckinit.c, include/rtems/score/iosh7750.h, include/rtems/score/ipl.h, include/rtems/score/ispsh7750.h, include/rtems/score/sh4_regs.h, include/rtems/score/sh7750_regs.h, include/sh/sh4uart.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c, score/ispsh7750.c, timer/timer.c: URL for license changed.
2001-10-262001-10-26 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill1-1/+1
* include/sh/sh4uart.h, sci/sh4uart.c: Minor fixes post merge.
2001-10-152001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+179
* include/sh4uart.h: move to include/sh/sh4uart.h. * include/ispsh7750.h: move to include/rtems/score/ispsh7750.h. * include/iosh7750.h: move include/rtems/score/iosh7750.h. * include/sh7750_regs.h: move to include/rtems/score/sh7750_regs.h. * include/rtems/score/ipl.h: move to include/rtems/score/ipl.h. * include/rtems/score/sh4_regs.h: Reintroduce from Alexandra Kossovsky's original sources. * include/Makefile.am: reflect changes above, remove EXTRA_DIST, require automake 1.5. * sci/Makefile.am: Disable compilation of console.c. * sci/sh4uart.c: include <sh/sh4uart.h>, add SH7750_SCSMR_CHK_S, remove SH4_CPU_HZ_Frequency; * score/isph7750.c: Remove #if !defined(sh7750), include sh4_regs.h.
