* sh7032/sci/sci.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* sh7045/sci/sci.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* sh7045/sci/sci_termios.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* sh7032/clock/ckinit.c, sh7032/delay/delay.c,
sh7032/include/ispsh7032.h, sh7032/sci/sci.c,
sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/clock/ckinit.c,
sh7045/include/ispsh7045.h, sh7045/sci/sci.c,
sh7045/sci/sci_termios.c, sh7045/score/cpu_asm.c,
sh7045/timer/timer.c, sh7750/clock/ckinit.c,
sh7750/include/rtems/score/ispsh7750.h, sh7750/include/sh/sh4uart.h,
sh7750/sci/sh4uart.c, sh7750/score/cpu_asm.c,
sh7750/score/ispsh7750.c, sh7750/timer/timer.c: Convert to using c99
fixed size types.
* sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c,
sh7750/score/cpu_asm.c: Use asm constraint "i" instead of "I" to
pass sizeof(Context_Control) to context switch.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am: Don't
include .../lib.am.
* ChangeLog: Merge-in sh7032/ChangeLog, sh7045/ChangeLog,
sh7750/ChangeLog.
* sh7032/ChangeLog, sh7045/ChangeLog, sh7750/ChangeLog: Remove.
* Makefile.am: Unconditionally build subdirs sh7032, sh7045, sh7750.
* configure.ac: Merge-in sh7032/configure.ac, sh7045/configure.ac,
sh7750/configure.ac.
Add AM_CONDITIONALS sh7032, sh7045, sh7750.
Reflect changes above. Add PREINSTALL_DIRS.
* sh7032/configure.ac, sh7045/configure.ac, sh7750/configure.ac:
Remove.
* sh7032/.cvsignore, sh7045/.cvsignore, sh7750/.cvsignore:
* configure.ac: Require automake 1.8.2.
Add subdir-objects to AUTOMAKE_OPTIONS.
Add AM_PROG_CC_C_0.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Misc cleanups and fixes.
* Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamps for preinstallation.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* clock/ckinit.c, include/io_types.h, include/iosh7045.h,
include/ispsh7045.h, include/sci.h, include/sci_termios.h,
include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, sci/sci_termios.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: URL for license
changed.
* score/cpu_asm.c: Removed incorrect statement about copyright
assignment.
* Makefile.am: Preinstall $(PROJECT_INCLUDE)/rtems/score.
* score/cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* sci/Makefile.am: Apply 2002-12-14 patch (Apparently dropped by CVS).
* score/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* clock/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* configure.ac: Apply 2002-11-07 patch (Apparently dropped by CVS).
* Makefile.am: Merge in include/Makefile.am.
* sh7045/score/ispsh7045.c: Fixed typos.
* sh7045/score/cpu_asm.c: Fixed typo.
* score/cpu_asm.c, score/ispsh7045.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* sci/Makefile.am: Use .$(OBJEXT) instead of .o.
* score/Makefile.am: Use .$(OBJEXT) instead of .o.
* include/ispsh7045.h, score/ispsh7045.c: Account for name change.
* include/iosh7045.h: Add SCI0_SMR, SCI1_SMR for sh7032
compatibility to make simsh happy.
* clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h,
include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* configure.in: Remove.
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector
number range check and handling of interrupt priority regs to
conform SH2 specs.
* sci/sci_termios.c: New file.
* include/sci_termios.h: New file.
* include/Makefile.am (EXTRA_DIST): Added sci_termios.h.
(include_sh_HEADERS): Added sci_termios.h.
* score/ispsh7045.c (isp): Calling an ISR with immediate argument
casued negative sign extension for vector numbers of 128 and
above. This was fixed.
* sci/sci.c: Cleaned initialization of SCI registers; added
necessary setup for new TERMIOS console cooperation
