PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* sci/Makefile.am: Apply 2002-12-14 patch (Apparently dropped by CVS).
* score/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* clock/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* configure.ac: Apply 2002-11-07 patch (Apparently dropped by CVS).
* Makefile.am: Merge in include/Makefile.am.
* sh7045/score/ispsh7045.c: Fixed typos.
* sh7045/score/cpu_asm.c: Fixed typo.
* score/cpu_asm.c, score/ispsh7045.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* sci/Makefile.am: Use .$(OBJEXT) instead of .o.
* score/Makefile.am: Use .$(OBJEXT) instead of .o.
* include/ispsh7045.h, score/ispsh7045.c: Account for name change.
* include/iosh7045.h: Add SCI0_SMR, SCI1_SMR for sh7032
compatibility to make simsh happy.
* clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h,
include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* configure.in: Remove.
* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector
number range check and handling of interrupt priority regs to
conform SH2 specs.
* sci/sci_termios.c: New file.
* include/sci_termios.h: New file.
* include/Makefile.am (EXTRA_DIST): Added sci_termios.h.
(include_sh_HEADERS): Added sci_termios.h.
* score/ispsh7045.c (isp): Calling an ISR with immediate argument
casued negative sign extension for vector numbers of 128 and
above. This was fixed.
* sci/sci.c: Cleaned initialization of SCI registers; added
necessary setup for new TERMIOS console cooperation
conform SH2 specs.
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* clock/ckinit.c (Install_clock): Modified MTU timer 0 initialization
to generate an interrupt exactly every 1us
* /dev/null moved to libmisc.
* Makefile.am, configure.in: Removed null directory.
* include/Makefile.am: Removed null.h.
* include/null.h, null/.cvsignore, null/Makefile.am, null/close.c,
null/cntrl.c, null/init.c, null/open.c, null/read.c, null/write.c:
Removed.
* clock/Makefile.am, null/Makefile.am, sci/Makefile.am,
timer/Makefile.am, score/Makefile.am: Include compile.am
are his notes:
installation prefix).
converted to automake.
serial drivers used in the 'gensh2' BSP for the Hitachi sh7045 CPU.
errors.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
John Mills <jmills@tga.com>.
fixes some problems:
I found the problem which prevented opening 'dev/sci1' (the default
console) with the 'gensh2' (sh7045) BSP. Both SCI ports were being
initialized against the same minor device number: '0'. When I tried to
open minor-device '1', it naturally crashed. Fixing that one value in the
'sci_device[]' array solved the problem and allowed 'hello.exe' to run.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
