esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
John Mills <jmills@tga.com>.
fixes some problems:
I found the problem which prevented opening 'dev/sci1' (the default
console) with the 'gensh2' (sh7045) BSP. Both SCI ports were being
initialized against the same minor device number: '0'. When I tried to
open minor-device '1', it naturally crashed. Fixing that one value in the
'sci_device[]' array solved the problem and allowed 'hello.exe' to run.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
