path: root/c/src/lib/libcpu/sh/sh7045/Makefile.am (follow)
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-051-1/+1
| | | | | | | | | * /dev/null moved to libmisc. * Makefile.am, configure.in: Removed null directory. * include/Makefile.am: Removed null.h. * include/null.h, null/.cvsignore, null/Makefile.am, null/close.c, null/cntrl.c, null/init.c, null/open.c, null/read.c, null/write.c: Removed.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-1/+1
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-1/+1
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-261-1/+1
* Patch rtems-rc-20000614-sh.tar.gz from Ralf CorsepiusJoel Sherrill2000-06-141-3/+4
| | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> that migrates the SH port to multilib'ing. This patch involved moving a number of files in the CVS repository, adding new files, and deleting files from their previous location. Ralf gave good instructions (not repeated here) and here are his notes: Note 1: In this version, I did not change the installation points of the headers which are moved inside of the source-tree. This is a temporary hack for not breaking compatibility with 4.5 based BSPs, but will probably not last once having real multilibs (We would have include file conflicts when several BSPs/CPU_MODELS share a common installation prefix). Note 2: I hope not to have broken too much, but I would not be astonished if something goes wrong. Note 3: There are more patches to come :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Removing Makefile.in and adding Makefile.am. These were missed in conversionJoel Sherrill1999-12-211-0/+10
