Update #3254.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
This is a preparation to remove the Giant lock.
Update #2555.
Avoid _Thread_Dispatch_increment_disable_level() and
_Thread_Dispatch_decrement_disable_level() and thus the Giant
lock.
Update #2555.
output.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
PR 1777/cpukit
* src/lib/libbsp/powerpc/shared/startup/panic.c,
src/lib/libcpu/sh/sh7032/score/cpu_asm.c,
src/lib/libcpu/sh/sh7045/score/cpu_asm.c,
src/lib/libcpu/sh/sh7750/score/cpu_asm.c,
src/lib/libcpu/sh/shgdb/score/cpu_asm.c: Consolidated access to
_Thread_Dispatch_disable_level.
* sh7032/delay/delay.c, sh7032/score/cpu_asm.c,
sh7032/score/ispsh7032.c, sh7045/sci/sci.c,
sh7045/sci/sci_termios.c, sh7045/score/cpu_asm.c,
sh7045/score/ispsh7045.c, sh7750/sci/sh4uart.c,
sh7750/score/cpu_asm.c, sh7750/score/ispsh7750.c,
shgdb/score/cpu_asm.c, shgdb/score/ispshgdb.c:
PR 1599/cpukit
* sh7032/score/cpu_asm.c, sh7045/score/cpu_asm.c,
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Rename
_Context_Switch_necessary to _Thread_Dispatch_necessary to more
properly reflect the intent.
PR 1573/cpukit
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Add a per cpu data
structure which contains the information required by RTEMS for each
CPU core. This encapsulates information such as thread executing,
heir, idle and dispatch needed.
sh7750/score/cpu_asm.c, shgdb/score/cpu_asm.c: Spacing.
* Makefile.am, configure.ac, sh7032/score/cpu_asm.c,
sh7045/score/cpu_asm.c, sh7750/score/cpu_asm.c: Move duplicated
context switch code to score/cpu and provide an interrupt handling
stub for the GDB SuperH simulator since it does not support
interrupts or devices. This has been used to run tests on the
simulator BSP as SH1, SH2, and SH4.
* shgdb/score/cpu_asm.c, shgdb/score/ispshgdb.c: New files.
* sh7032/clock/ckinit.c, sh7045/clock/ckinit.c, sh7750/clock/ckinit.c:
The Shared Memory Driver no longer requires the special IOCTL in
Clock_control. This was a hack which has existed since before the
Classic API Timer Manager was implemented. All implementations of and
references to Clock_control were removed.
* sh7032/timer/timer.c, sh7045/timer/timer.c, sh7750/timer/timer.c:
Rename timer driver methods to follow RTEMS programming conventions.
* sh7032/clock/ckinit.c, sh7032/delay/delay.c, sh7032/timer/timer.c,
sh7045/clock/ckinit.c, sh7045/timer/timer.c, sh7750/clock/ckinit.c,
sh7750/timer/timer.c: Eliminate the clicks_per_microsecond field in
the SuperH CPU Table and define another mechanism for drivers to
obtain this information.
PR 1257/bsps
* sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/score/cpu_asm.c,
sh7045/timer/timer.c, sh7750/score/cpu_asm.c, sh7750/timer/timer.c:
Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
Remove build-variant support.
* sh7032/sci/sci.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* sh7045/sci/sci.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* sh7045/sci/sci_termios.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* sh7032/clock/ckinit.c, sh7750/include/sh/sh4uart.h,
sh7750/sci/sh4uart.c: Cosmetics.
sh7032/include/ispsh7032.h, sh7032/sci/sci.c,
sh7032/score/cpu_asm.c, sh7032/timer/timer.c, sh7045/clock/ckinit.c,
sh7045/include/ispsh7045.h, sh7045/sci/sci.c,
sh7750/include/rtems/score/ispsh7750.h, sh7750/include/sh/sh4uart.h,
sh7750/sci/sh4uart.c, sh7750/score/cpu_asm.c,
sh7750/score/ispsh7750.c, sh7750/timer/timer.c: Convert to using c99
fixed size types.
sh7750/score/cpu_asm.c: Use asm constraint "i" instead of "I" to
pass sizeof(Context_Control) to context switch.
* sh7032/Makefile.am, sh7045/Makefile.am, sh7750/Makefile.am: Don't
include .../lib.am.
* ChangeLog: Merge-in sh7032/ChangeLog, sh7045/ChangeLog,
sh7750/ChangeLog.
* sh7032/ChangeLog, sh7045/ChangeLog, sh7750/ChangeLog: Remove.
* Makefile.am: Unconditionally build subdirs sh7032, sh7045, sh7750.
* configure.ac: Merge-in sh7032/configure.ac, sh7045/configure.ac,
sh7750/configure.ac.
Add AM_CONDITIONALS sh7032, sh7045, sh7750.
Reflect changes above. Add PREINSTALL_DIRS.
* sh7032/configure.ac, sh7045/configure.ac, sh7750/configure.ac:
Remove.
* sh7032/.cvsignore, sh7045/.cvsignore, sh7750/.cvsignore:
* configure.ac: Require automake 1.8.2.
Add subdir-objects to AUTOMAKE_OPTIONS.
Add AM_PROG_CC_C_0.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Misc cleanups and fixes.
* Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamps for preinstallation.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* clock/ckinit.c, delay/delay.c, include/iosh7032.h,
include/ispsh7032.h, include/sci.h, include/sh7_pfc.h,
include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c,
timer/timer.c: URL for license changed.
* score/cpu_asm.c: Removed incorrect statement about copyright
assignment.
