* configure.ac: Remove RTEMS_CHECK_CPU.
* clock/ckinit.c, delay/delay.c, include/iosh7032.h,
include/ispsh7032.h, include/sci.h, include/sh7_pfc.h,
include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c,
timer/timer.c: URL for license changed.
* score/cpu_asm.c: Removed incorrect statement about copyright
assignment.
* Makefile.am: Preinstall $(PROJECT_INCLUDE)/rtems/score.
* score/cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* delay/Makefile.am: Removed.
* clock/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* delay/Makefile.am: Ditto.
* sci/Makefile.am: Ditto.
* score/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* Makefile.am: Merge in include/Makefile.am.
* delay/delay.c, score/ispsh7032.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* delay/Makefile.am: Use .$(OBJEXT) instead of .o.
* sci/Makefile.am: Use .$(OBJEXT) instead of .o.
* score/Makefile.am: Use .$(OBJEXT) instead of .o.
* score/cpu_asm.c: Adapt inline asm to gcc-3.0.4.
* include/ispsh7032.h, score/ispsh7032.c: Account for name change.
* delay/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/Makefile.am: Remove EXTRA_DIST.
timer/timer.c: Fixed typo.
* configure.in: Remove.
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* /dev/null moved to libmisc.
* Makefile.am, configure.in: Removed null directory.
* include/Makefile.am: Removed null.h.
* include/null.h, null/.cvsignore, null/Makefile.am, null/close.c,
null/cntrl.c, null/init.c, null/open.c, null/read.c, null/write.c:
Removed.
* clock/Makefile.am, delay/Makefile.am, null/Makefile.am,
sci/Makefile.am, timer/Makefile.am, score/Makefile.am: Include
compile.am
are his notes:
installation prefix).
converted to automake.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
TPC values. Reviewed by Ralf Corsepius <corsepiu@faw.uni-ulm.de>
who originally submitted the file.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
BSP needs to be eliminated.
