path: root/c/src/lib/libcpu/sh/sh7032/timer (unfollow)
1998-09-29Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-3/+3
Please find enclosed a patch which enables me to build the bare-bsp for sh-rtems. Changes: 1. Add preinstall to libbsp/bare/include/Makefile.in 2. Removed FORCEIT, add preinstall to libbsp/sh/gensh1/include/Makefile.in 3. Disabled support of set_vector from sh code (shared/setvec.c is still present but isn't used anymore), set_vector replaced with standard rtems functions. Problems still present: 1. Support of spin-delays in bare bsp 2. Proper support of cpu frequency To configure I used: <srcdir>/configure \ --target=sh-rtems \ --prefix=<instdir>/sh-bare \ --enable-bare-cpu-model=sh7032 \ --enable-bare-cpu-cflags='-Wall -m1 -DMHZ=20 -DCPU_CONSOLE_DEVNAME="\"/dev/null\""' --enable-rtemsbsp=bare \ --disable-networking \ --disable-cxx \ --disable-posix \ --disable-tests IMO, if there are no objections to this patch, a similar approach should be applied to all CPUs/BSPs (esp. hppa1.1, mips64orion, ppc403, because they apply set_vector inside of libcpu).
1998-03-20New port from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2-0/+264
