path: root/c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (unfollow)
2003-01-162003-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-27/+0
* Makefile.am: Merge-in subdir Makefile.ams * configure.ac: Reflect changes above. * score/Makefile.am: Removed. * sci/Makefile.am: Removed. * timer/Makefile.am: Removed. * clock/Makefile.am: Removed. * delay/Makefile.am: Removed.
2002-12-142002-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-4/+1
* clock/Makefile.am: Eliminate *_O_FILES. Don't include @RTEMS_BSP@.cfg. * delay/Makefile.am: Ditto. * sci/Makefile.am: Ditto. * score/Makefile.am: Ditto. * timer/Makefile.am: Ditto.
2002-08-112002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* clock/Makefile.am: Use .$(OBJEXT) instead of .o. * delay/Makefile.am: Use .$(OBJEXT) instead of .o. * sci/Makefile.am: Use .$(OBJEXT) instead of .o. * score/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * delay/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * sci/Makefile.am: Remove AUTOMAKE_OPTIONS. * score/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* clock/Makefile.am, delay/Makefile.am, null/Makefile.am, sci/Makefile.am, timer/Makefile.am, score/Makefile.am: Include compile.am
2000-06-14Patch rtems-rc-20000614-sh.tar.gz from Ralf CorsepiusJoel Sherrill1-2/+2
<corsepiu@faw.uni-ulm.de> that migrates the SH port to multilib'ing. This patch involved moving a number of files in the CVS repository, adding new files, and deleting files from their previous location. Ralf gave good instructions (not repeated here) and here are his notes: Note 1: In this version, I did not change the installation points of the headers which are moved inside of the source-tree. This is a temporary hack for not breaking compatibility with 4.5 based BSPs, but will probably not last once having real multilibs (We would have include file conflicts when several BSPs/CPU_MODELS share a common installation prefix). Note 2: I hope not to have broken too much, but I would not be astonished if something goes wrong. Note 3: There are more patches to come :)
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-4/+2
2000-01-31Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill1-15/+10
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
1999-12-21Removing Makefile.in and adding Makefile.am. These were missed in conversionJoel Sherrill1-0/+37
