* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
* mpc8xx/console-generic/console-generic.c:
Add support for configuration parameters in NVRAM
* ChangeLog: File paths corrected.
* console-generic/console-generic.c: Addition of support for shared
printk and no termios.
2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* console-generic/console-generic.c(m8xx_uart_pollWrite):
Flush actual buffer.
were needed to move exception processing to score/cpu.
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
_Interrupt_Manager_initialization.
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
mpc8xx libcpu support for the first time and remove includes
of bsp.h, references to BSP_Configuration, and Cpu_table. All
of these can be obtained directly from RTEMS now.
responsibility to explicitly pick up the components they
require. This makes it easier to override default implmentations.
score/cpu/powerpc.
shared source code.
significant things:
and PowerPC
same code base.
John reports this works on the 821 and 860.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
converted to automake.
which fixes some PowerPC specific bugs.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
and reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de> on the mpc505.
<valette@crf.canon.fr> and Jay Kulpinski <jskulpin@eng01.gdds.com>.
old_exception_processing tree.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
./bootstrap
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
ppc6xx.
ppc6xx.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
