format
warnings
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Use r8 instead of r5 to slightly optimize _CPU_Context_switch(). It is
not a big deal, however, we already assume r12 is used by
_CPU_Context_switch(). Treat r5 the in same way.
Update #2751.
Update #2751.
Update #2751.
Callers of _Thread_Do_dispatch() must have a valid
Per_CPU_Control::Stats::thread_dispatch_disabled_instant.
Call _Profiling_Outer_most_interrupt_entry_and_exit() with the interrupt
stack to not exceed Per_CPU_Control::Interrupt_frame.
Update #2751.
The MPC5XX support uses a legacy interrupt/exception infrastructure.
Close #2819.
Update #2751.
Use a processor-specific interrupt frame during context switches in case
the executing thread is longer executes on the processor and the heir
thread is about to start execution. During this period we must not use
a thread stack for interrupt processing.
Update #2809.
Rename ppc_exc_min_frame to CPU_Interrupt_frame. Move it and the
corresponding defines to <rtems/score/cpuimpl.h>.
Update #2809.
The only remaining user of CPU_Interrupt_frame on PowerPC is the mpc5xx
support. Move it to here.
Update #2809.
This type is not relevant for the code since only a pointer is passed
around.
Update #2809.
Add _CPU_Get_current_per_CPU_control() on SMP configurations. Use SPRG0
for the current per-CPU control. This reduces the code size by three
instructions and is slightly faster.
Update #2805.
Update #2797.
We need the unmodified r4 for get_potential_new_heir.
This partially reverts commit 8d785f72d9610fb80a65d7848404f0f7507e026c.
Properly pass the stack aligned context to _CPU_Context_switch_altivec()
since _CPU_altivec_ctxt_off defined via ppc_context.
Close #2761.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
This is a preparation to remove the Giant lock.
Update #2555.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
Update #2555.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
According to the C11 and C++11 memory models only a read-modify-write
operation guarantees that we read the last value written in modification
order. Avoid the sequential consistent thread fence and instead use the
inter-processor interrupt to set the thread dispatch necessary
indicator.
Close #2373.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Store the floating-point unit property in the thread control block
regardless of the CPU_HARDWARE_FP and CPU_SOFTWARE_FP settings. Make
sure the floating-point unit is only enabled for the corresponding
multilibs. This helps targets which have a volatile only floating point
context like SPARC for example.
Update #2356.
Update #2271.
fix warning
PowerPC Book E: Account for an extra tick period if a tick increment's
pending.
Close #2230.
Close #2237.
Add AltiVec and FPU support to the Context_Control in case we use the
e6500 multilib.
Add PPC_MULTILIB_ALTIVEC and PPC_MULTILIB_FPU multilib defines. Add
non-volatile AltiVec and FPU context to Context_Control. Add save/restore of
non-volatile AltiVec and FPU to _CPU_Context_switch(). Add save/restore
of volatile AltiVec and FPU context to the exception code. Adjust data
cache optimizations for the new context and cache line size.
This is not correct, but works for now.
Provide floating point context support only if PPC_HAS_FPU == 1.
Use it for the default PPC_CACHE_ALIGNMENT. Use it for
PPC_STRUCTURE_ALIGNMENT.
Do not warn about not implemented cache functions.
Give the BSP the ability to define PPC_CACHE_ALIGNMENT.
