line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
This type is not relevant for the code since only a pointer is passed
around.
Update #2809.
close 1405
output.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
This file was originally modified by me to support the PPC440 of the virtex5
BSP. I have since discovered that the clock driver built with the MVME3100
BSP works out of the box for the virtex5 and so have switched to using that.
This file is reverted to the way it was before I touched it, modulo whitespace,
making some functions static (to avoid compiler warnings) and changes by others.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
This commit covers at least PR2020, 2022, and 2023. This
patch adds all of the code for both BSPs, modifications
to libcpu/powerpc for the ppc440, and some updates to the
BSPs from follow up review and testing.
These BSPs should be good baselines for future development.
The configurations used by Ric are custom and have a non-standard
NIC. They also do not have a UART. Thus the current console
driver just prints to a RAM buffer.
The NIC and UART support are left for future work. When the UART
support is added, moving the existing "to RAM" console driver to
a shared location is likely desirable because boards with no debug
UART port are commonly deployed. This would let printk() go to RAM.
* ppc403/clock/clock.c (ClockOn): Define pvr only for "ifndef ppc405".
* ppc403/clock/clock.c (Install_clock): Remove unused var "pvr".
* e500/mmu/mmu.c, mpc505/ictrl/ictrl.c, mpc505/timer/timer.c,
mpc5xx/ictrl/ictrl.c, mpc5xx/timer/timer.c,
mpc6xx/altivec/vec_sup.c, mpc6xx/clock/c_clock.c,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/pte121.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, new-exceptions/cpu.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
ppc403/clock/clock.c, ppc403/console/console.c,
ppc403/console/console.c.polled, ppc403/console/console405.c,
ppc403/irq/ictrl.c, ppc403/tty_drv/tty_drv.c,
rtems/powerpc/cache.h, shared/include/powerpc-utility.h, shared/src/cache.c:
* ppc403/clock/clock.c, ppc403/console/console405.c,
ppc403/tty_drv/tty_drv.c: Remove warnings and simple vectored
interrupt support.
* mpc5xx/clock/clock.c, mpc6xx/clock/c_clock.c, mpc8260/clock/clock.c,
mpc8xx/clock/clock.c, ppc403/clock/clock.c, ppc403/clock/clock_4xx.c:
The Shared Memory Driver no longer requires the special IOCTL in
Clock_control. This was a hack which has existed since before the
Classic API Timer Manager was implemented. All implementations of and
references to Clock_control were removed.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c, mpc6xx/timer/timer.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, ppc403/timer/timer.c:
Rename timer driver methods to follow RTEMS programming conventions.
* ppc403/clock/clock.c: Added (conditionally compiled)
code so that a BSP can choose to hook the timer exception
directly rather than going through the interrupt dispatcher.
* ChangeLog, mpc8xx/clock/clock.c, ppc403/clock/clock.c,
ppc403/irq/ictrl.h, rtems/powerpc/powerpc.h:
Removed all macro definitions which depended on
the compiler defining a PPC CPU-model dependent
symbol from files in cpukit.
Macros which were not used by cpukit have been
moved to libcpu/powerpc/rtems/powerpc/powerpc.h.
* ppc403/tty_drv/tty_drv.c, ppc403/console/console405.c:
../ictrl/ictrl.h has gone; include ../irq/ictrl.h
* ppc403/console/console.c: Correct include path.
* ppc403/clock/clock.c: Now compiles and links.
* mpc5xx/clock/clock.c, mpc5xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/cpm/brg.c, mpc8260/timer/timer.c, mpc8xx/clock/clock.c,
mpc8xx/console-generic/console-generic.c, mpc8xx/timer/timer.c,
new-exceptions/raw_exception.c, old-exceptions/cpu.c,
ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c: Eliminate PowerPC specific elements from
the CPU Table. They have been replaced with variables named bsp_XXX
as needed.
PR 1257/bsps
* mpc5xx/exceptions/raw_exception.c, mpc5xx/irq/irq.c,
mpc6xx/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c, new-exceptions/raw_exception.c,
ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c: Code outside of cpukit
should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
exception handling
* ppc403/console/console405.c: Rename round to spiBaudRound
(Conflict with C99). Make spiBaudRound static.
* mpc505/vectors/vectors.S, ppc403/vectors/vectors.S:
Remove PPC_ABI_POWEROPEN.
Remove PPC_ABI_GCC27.
* ppc403/vectors/vectors.S: Remove XCOFF support.
* mpc505/Makefile.am, mpc5xx/Makefile.am, mpc6xx/Makefile.am,
mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am,
shared/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* ppc403/tty_drv/tty_drv.c: Remove warnings.
shared/Makefile.am: Remove build-variant support.
