2008-02-19 | Remove (Abandoned). | Ralf Corsepius | 1 | -435/+0 | |
2004-04-02 | * ppc403/vectors/align_h.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 1 | -1/+1 | |
1999-11-09 | Added #define to make this file exactly like its siblings in mpc821 | Joel Sherrill | 1 | -1/+2 | |
and mpc860 directories. | |||||
1999-11-04 | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1 | -1/+1 | |
particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
1998-12-14 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1 | -0/+0 | |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | |||||
1998-04-14 | new files | Joel Sherrill | 1 | -0/+0 | |
1997-01-29 | Minor change to eliminate incorrect use of unaligned register. | Joel Sherrill | 1 | -1/+2 | |
1995-12-05 | update from Andy Bray <andy@i-cubed.co.uk> | Joel Sherrill | 1 | -14/+11 | |
1995-09-26 | new file | Joel Sherrill | 1 | -0/+436 | |
