* mpc505/Makefile.am, mpc5xx/Makefile.am, mpc6xx/Makefile.am,
mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am,
shared/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
shared/Makefile.am: Remove build-variant support.
* mpc505/Makefile.am, mpc6xx/Makefile.am, mpc8260/Makefile.am,
mpc8xx/Makefile.am, ppc403/Makefile.am: Don't include .../lib.am.
* configure.ac: Require automake >= 1.8.2.
* Makefile.am, mpc505/Makefile.am, mpc6xx/Makefile.am,
shared/Makefile.am: Use automake compilation rules.
Add PREINSTALL_DIRS.
* mpc505/Makefile.am: Ditto.
* mpc6xx/Makefile.am: Ditto.
* mpc8260/Makefile.am: Ditto.
* mpc8xx/Makefile.am: Ditto.
* ppc403/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* ppc403/Makefile.am: Fix typo in vectors' compilation rule.
* shared/Makefile.am: Use $(top_srcdir)/../shared instead of
relative subdirs.
* ppc403/clock/Makefile.am: Remove.
* ppc403/console/Makefile.am: Remove.
* ppc403/ictrl/Makefile.am: Remove.
* ppc403/timer/Makefile.am: Remove.
* ppc403/tty_drv/Makefile.am: Remove.
* ppc403/vectors/Makefile.am: Remove.
* ppc403/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to ppc403/Makefile.ams.
* Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/Makefile.am: Reformat.
* mpc505/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/timer/Makefile.am: Reformat.
* mpc505/vectors/Makefile.am: Reformat.
* mpc6xx/Makefile.am: Reformat.
* mpc6xx/clock/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/mmu/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/timer/Makefile.am: Reformat.
* mpc6xx/wrapup/Makefile.am: Reformat.
* mpc8260/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/clock/Makefile.am: Reformat.
* mpc8260/console-generic/Makefile.am: Reformat.
* mpc8260/cpm/Makefile.am: Reformat.
* mpc8260/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/mmu/Makefile.am: Reformat.
* mpc8260/timer/Makefile.am: Reformat.
* mpc8xx/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/clock/Makefile.am: Reformat.
* mpc8xx/console-generic/Makefile.am: Reformat.
* mpc8xx/cpm/Makefile.am: Reformat.
* mpc8xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/mmu/Makefile.am: Reformat.
* mpc8xx/timer/Makefile.am: Reformat.
* ppc403/Makefile.am: Reformat.
* ppc403/clock/Makefile.am: Reformat.
* ppc403/console/Makefile.am: Reformat.
* ppc403/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/timer/Makefile.am: Reformat.
* ppc403/tty_drv/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/vectors/Makefile.am: Reformat.
* shared/Makefile.am: Reformat.
* shared/include/Makefile.am: Reformat. Use dirstamp for preinstallation.
* shared/src/Makefile.am: Reformat. Use dirstamp for preinstallation.
* wrapup/Makefile.am: Reformat.
mpc505/Makefile.am: Reflect having moved automake.
mpc505/ictrl/Makefile.am: Reflect having moved automake.
mpc505/timer/Makefile.am: Reflect having moved automake.
mpc505/vectors/Makefile.am: Reflect having moved automake.
mpc6xx/Makefile.am: Reflect having moved automake.
mpc6xx/clock/Makefile.am: Reflect having moved automake.
mpc6xx/exceptions/Makefile.am: Reflect having moved automake.
mpc6xx/mmu/Makefile.am: Reflect having moved automake.
mpc6xx/timer/Makefile.am: Reflect having moved automake.
mpc6xx/wrapup/Makefile.am: Reflect having moved automake.
mpc8260/Makefile.am: Reflect having moved automake.
mpc8260/clock/Makefile.am: Reflect having moved automake.
mpc8260/console-generic/Makefile.am: Reflect having moved automake.
mpc8260/cpm/Makefile.am: Reflect having moved automake.
mpc8260/exceptions/Makefile.am: Reflect having moved automake.
mpc8260/mmu/Makefile.am: Reflect having moved automake.
mpc8260/timer/Makefile.am: Reflect having moved automake.
mpc8xx/Makefile.am: Reflect having moved automake.
mpc8xx/clock/Makefile.am: Reflect having moved automake.
mpc8xx/console-generic/Makefile.am: Reflect having moved automake.
mpc8xx/cpm/Makefile.am: Reflect having moved automake.
mpc8xx/exceptions/Makefile.am: Reflect having moved automake.
mpc8xx/mmu/Makefile.am: Reflect having moved automake.
mpc8xx/timer/Makefile.am: Reflect having moved automake.
ppc403/Makefile.am: Reflect having moved automake.
ppc403/clock/Makefile.am: Reflect having moved automake.
ppc403/console/Makefile.am: Reflect having moved automake.
ppc403/ictrl/Makefile.am: Reflect having moved automake.
ppc403/timer/Makefile.am: Reflect having moved automake.
ppc403/tty_drv/Makefile.am: Reflect having moved automake.
ppc403/vectors/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/include/Makefile.am: Reflect having moved automake.
shared/src/Makefile.am: Reflect having moved automake.
* mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS.
process was captured as PR50.
* ppc403/console/console405.c ppc403/tty_drv/.cvsignore,
ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c,
ppc403/tty_drv/tty_drv.h: New files.
* Makefile.am, README, configure.ac, old_exception_processing/cpu.c,
old_exception_processing/cpu.h, ppc403/Makefile.am,
ppc403/clock/clock.c, ppc403/console/Makefile.am,
ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h,
ppc403/timer/timer.c: Modified.
