* new_exception_processing/Makefile.in,
new_exception_processing/.cvsignore,
new_exception_processing/Makefile.am,
new_exception_processing/c_isr.inl,
new_exception_processing/cpu.c, new_exception_processing/cpu.h,
new_exception_processing/cpu_asm.S,
old_exception_processing/Makefile.in,
old_exception_processing/.cvsignore,
old_exception_processing/Makefile.am, old_exception_processing/README,
old_exception_processing/TODO, old_exception_processing/c_isr.inl,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/irq_stub.S,
old_exception_processing/ppc_offs.h,
old_exception_processing/ppccache.c, old_exception_processing/rtems.S:
Deleted since now under libbsp.
process was captured as PR50.
* ppc403/console/console405.c ppc403/tty_drv/.cvsignore,
ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c,
ppc403/tty_drv/tty_drv.h: New files.
* Makefile.am, README, configure.ac, old_exception_processing/cpu.c,
old_exception_processing/cpu.h, ppc403/Makefile.am,
ppc403/clock/clock.c, ppc403/console/Makefile.am,
ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h,
ppc403/timer/timer.c: Modified.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
* old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay().
Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* shared/include/cpu.h: Renamed delay() to rtems_bsp_delay().
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
* Added full support for MPC505.
* mpc505/ictrl: New directory.
* configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition.
* mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am,
mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files.
* mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h".
* mpc505/vectors/Makefile.am: alignment exception handler now included.
* mpc505/vectors/vectors.S: Now use constants for exception numbers.
* old_exception_processing/ppc_offs.h: New file.
* old_exception_processing/Makefile.am: Account for ppc_offs.h.
* old_exception_processing/cpu.h: Make Nest and Disable levels volatile.
* old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
_Interrupt_Manager_initialization.
significant things:
and PowerPC
same code base.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
BSP needs to be eliminated.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
