2005-11-04 | Remove (Merged into ../ChangeLog) | Ralf Corsepius | 1 | -192/+0 | |
2005-02-15 | 2005-02-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* cpu.c: Use _CPU_MSR_GET instead of _CPU_MSR_Value (Unify old/new exception processing API). | |||||
2005-02-15 | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* cpu.c (ppc_exception_vector_addr): Merge ppc603 and ppc603e cases. | |||||
2005-02-14 | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>. | |||||
2005-02-13 | 2005-02-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* cpu.c: Add _PPC_MSR_DISABLE_MASK. | |||||
2005-02-12 | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am, configure.ac: Remove (Unused). | |||||
2005-02-10 | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_POWEROPEN. | |||||
2005-02-09 | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_GCC27. | |||||
2005-01-07 | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
2005-01-03 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Remove build-variant support. | |||||
2004-10-20 | 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
PR 696/bsps * cpu.c: Include bsp.h. | |||||
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. | |||||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* cpu.c, ppccache.c: Convert to using c99 fixed size types. | |||||
2004-01-30 | 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Add RTEMS_PROG_CCAS. * Makefile.am: Use automake compilation rules. | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Add PREINSTALL_DIRS. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | |||||
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-02 | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reformat for preinstallation dirstamp support. | |||||
* Makefile.am: Remove all-local: $(ARCH). | |||||
2003-10-22 | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
2003-10-21 | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_CHECK_CPU. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* cpu.c, cpu_asm.S: URL for license changed. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-18 | Fix broken ChangeLog entries. | Ralf Corsepius | 1 | -1/+1 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
Makefile.am: Reflect having moved automake. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). | |||||
2002-12-17 | 2002-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Don't include @RTEMS_BSP@.cfg. * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-09-14 | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to eliminate warning. | |||||
2002-08-11 | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use .$(OBJEXT) instead of .o. | |||||
2002-07-21 | 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Fix oversights in previous patch. | |||||
2002-07-21 | 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* rtems.S: Remove. * Makefile.am: Reflect having removed rtems.S. Use AM_CPPFLAGS instead of INCLUDES (Latest automake standard). | |||||
2002-05-01 | 2002-04-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* cpu.c: Include <rtems/powerpc/cache.h>. | |||||
2002-04-18 | 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* rtems/score/cpu.h: Removed. * Makefile.am: Reflect changes above. | |||||
2002-04-03 | 2001-04-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/cpu.h: Account for name change. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+7 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-11-28 | 2001-11-28 Joel Sherrill <joel@OARcorp.com>, | Joel Sherrill | 1 | -0/+10 | |
This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. * rtems/score/c_isr.inl: Deleted and contents merged into cpu.c. * cpu.c: Received contents of c_isr.inl. * Makefile.am: Deleted reference to c_isr.inl. | |||||
2001-11-27 | 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure. | |||||
2001-11-21 | 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* Makefile.am: Preinstall c_isr.inl (HACK). * ChangeLog: New file. |
