Update #3285.
Rename ppc_exc_min_frame to CPU_Interrupt_frame. Move it and the
corresponding defines to <rtems/score/cpuimpl.h>.
Update #2809.
Add AltiVec and FPU support to the Context_Control in case we use the
e6500 multilib.
Add PPC_MULTILIB_ALTIVEC and PPC_MULTILIB_FPU multilib defines. Add
non-volatile AltiVec and FPU context to Context_Control. Add save/restore of
non-volatile AltiVec and FPU to _CPU_Context_switch(). Add save/restore
of volatile AltiVec and FPU context to the exception code. Adjust data
cache optimizations for the new context and cache line size.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
Add bsp_generic_fatal().
Delete ppc_exc_vector_base. Add and use
ppc_exc_initialize_with_vector_base().
In combination with the PPC_EXC_CONFIG_USE_FIXED_HANDLER option this
removes all dependencies on valid read-write data. The exception
handling must be statically configured and all components reside in
read-only sections.
The powerpc port uses now a unified CPU_Exception_frame. This resulted
in a CPU_Exception_frame layout change for the MPC5XX.
* e500/mmu/mmu.c, mpc505/ictrl/ictrl.c, mpc505/timer/timer.c,
mpc5xx/ictrl/ictrl.c, mpc5xx/timer/timer.c,
mpc6xx/altivec/vec_sup.c, mpc6xx/clock/c_clock.c,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/pte121.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, new-exceptions/cpu.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
ppc403/clock/clock.c, ppc403/console/console.c,
ppc403/console/console.c.polled, ppc403/console/console405.c,
ppc403/irq/ictrl.c, ppc403/tty_drv/tty_drv.c,
rtems/powerpc/cache.h, shared/include/powerpc-utility.h, shared/src/cache.c:
* mpc5xx/exceptions/raw_exception.c, mpc5xx/exceptions/raw_exception.h,
mpc5xx/include/console.h, mpc5xx/include/mpc5xx.h, mpc5xx/irq/irq.c,
mpc5xx/irq/irq.h, mpc5xx/irq/irq_asm.S, mpc5xx/vectors/vectors.h,
mpc5xx/vectors/vectors_init.c, mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h,
mpc6xx/mmu/mmuAsm.S, new-exceptions/bspsupport/irq.c,
new-exceptions/bspsupport/irq_supp.h,
new-exceptions/bspsupport/nested_irq_test.c,
new-exceptions/bspsupport/ppc_exc_address.c,
new-exceptions/bspsupport/ppc_exc_categories.c,
new-exceptions/bspsupport/ppc_exc_global_handler.c,
new-exceptions/bspsupport/ppc_exc_hdl.c,
new-exceptions/bspsupport/ppc_exc_prologue.c,
new-exceptions/bspsupport/ppc_exc_test.c,
new-exceptions/bspsupport/vectors.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: Fix typo where
license said found in found in.
* new-exceptions/bspsupport/ppc_exc_address.c,
new-exceptions/bspsupport/ppc_exc_initialize.c: Fixed IVOR handling for
e200z0 and e200z1.
* shared/include/cpuIdent.c, shared/include/cpuIdent.h: Added support
for e500v2. Removed IVPR/IVOR/HWIVOR features since they are included
in Book E.
* new-exceptions/bspsupport/vectors.h,
new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_prologue.c: Added support for
e500v2. Added exception vector defines for Book E types. Removed
e200 exception vector defines. Added e500 exception vector defines.
Unified IVOR calculation for e200 and e500 (e200z1 has hard wired
IVOR values).
* new-exceptions/cpu.c, new-exceptions/cpu_asm.S,
new-exceptions/bspsupport/ppc_exc_asm_macros.h,
new-exceptions/bspsupport/vectors.h:
Added AltiVec support (save/restore volatile vregs
across exceptions).
