In combination with the PPC_EXC_CONFIG_USE_FIXED_HANDLER option this
removes all dependencies on valid read-write data. The exception
handling must be statically configured and all components reside in
read-only sections.
In case a BSP enables this option, then fixed high level exception
handler will be used. For normal asynchronous exceptions this is
bsp_interrupt_dispatch() and for other exceptions this is the handler
from the read-only ppc_exc_handler_table. The global handler is
C_exception_handler(). This avoids some dependencies on valid
read-write data.
PR 1799/bsps
* new-exceptions/bspsupport/ppc_exc_async_normal.S: New file.
* new-exceptions/cpu.c, new-exceptions/cpu_asm.S,
new-exceptions/bspsupport/ppc_exc_asm_macros.h,
new-exceptions/bspsupport/ppc_exc_global_handler.c,
new-exceptions/bspsupport/ppc_exc_prologue.c,
new-exceptions/bspsupport/vectors.h: Added support for SPE.
* configure.ac, preinstall.am, Makefile.am: Added support for qoriq
BSPs.
* new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_naked.S,
new-exceptions/bspsupport/ppc_exc_prologue.c: Branch targets are now
global for all minimal prologues. Generate branch instruction in
minimal prologues.
* new-exceptions/bspsupport/ppc_exc_asm_macros.h: Added include of
bspopts to resolve compilation problem.
PR 1573/cpukit
* mpc5xx/irq/irq.c, mpc5xx/irq/irq_asm.S,
new-exceptions/bspsupport/ppc_exc_hdl.c: Add a per cpu data structure
which contains the information required by RTEMS for each CPU core.
This encapsulates information such as thread executing, heir, idle
and dispatch needed.
new-exceptions/bspsupport/ppc_exc_initialize.c,
Added AltiVec support (save/restore volatile vregs
across exceptions).
a test to TEST_LOCK_crit so that a context switch is
always prevented if MSR_CE is not set in the interrupt mask.
(Support mode where the user wants to leave MSR_CE always enabled
but abstains from calling OS primitives from the exception
handler.)
* new-exceptions/bspsupport/ppc_exc_asm_macros.S,
new-exceptions/bspsupport/ppc_exc_bspsupp.h,
new-exceptions/bspsupport/ppc_exc_hdl.c,
new-exceptions/bspsupport/vectors_init.c:
fixed and enabled stack-switching algorithm which figures out
if we already run on the ISR stack rather than relying on the
_ISR_Nest_level.
Added 'ppc_exc_crit_always_enabled' variable which defines
the semantics of critical interrupts. Added a test to
TEST_LOCK_crit so that calling ppc_exc_wrapup() (and
possibly the dispatcher) is always skipped if the BSP/user
wants to leave critical interrupts always enabled (at the
expense of having no OS support).
changed TEST_LOCK_mchk so that asynchronous machine-check
handlers never call ppc_exc_wrapup() (and the dispatcher).
We don't want to disable MSR_ME ever (to avoid checkstops)
and hence asynchronous MEs must not use OS services anyways.
added and commented new variables 'ppc_exc_intr_stack_size'
'ppc_exc_crit_always_enabled'.
* new-exceptions/bspsupport/ppc_exc_asm_macros.h,
new-exceptions/bspsupport/README,
Thomas Doerfler clarified (thanks!) that raising an
exception and executing the 1st instruction is not
an atomical operation. I added a fix to the code that
checks if a lower-priority interrupt is under way:
we now not only test if the 'lock' variable was set
but also check if the interrupted PC points to the
'write lock' instruction.
Added more comments and updated README.
* new-exceptions/bspsupport/ppc_exc_asm_macros.h: bugfix;
need to crand not cror when testing lower priority locks
during machine-check handling.
need to andc with irq mask when disabling interrupts.
* new-exceptions/bspsupport/, new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_test.c,
new-exceptions/bspsupport/vectors.h,
new-exceptions/bspsupport/vectors_init.c,
new-exceptions/bspsupport/irq.c,
new-exceptions/bspsupport/nested_irq_test.c:
New files. Added 'middleware' code for helping BSPs implement
exception and interrupt handling and implementing the 'new'
RTEMS IRQ API (which I personally dislike).
