* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc6xx/exceptions/raw_exception.c, mpc6xx/exceptions/raw_exception.h,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S,
mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/brg.c,
mpc8260/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.h, mpc8260/include/cpm.h,
mpc8260/include/mmu.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.h,
mpc8xx/include/cpm.h, mpc8xx/include/mmu.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c.polled, ppc403/timer/timer.c,
rtems/powerpc/debugmod.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: URL for license
changed.
mpc505/Makefile.am: Reflect having moved automake.
mpc505/ictrl/Makefile.am: Reflect having moved automake.
mpc505/timer/Makefile.am: Reflect having moved automake.
mpc505/vectors/Makefile.am: Reflect having moved automake.
mpc6xx/Makefile.am: Reflect having moved automake.
mpc6xx/clock/Makefile.am: Reflect having moved automake.
mpc6xx/exceptions/Makefile.am: Reflect having moved automake.
mpc6xx/mmu/Makefile.am: Reflect having moved automake.
mpc6xx/timer/Makefile.am: Reflect having moved automake.
mpc6xx/wrapup/Makefile.am: Reflect having moved automake.
mpc8260/Makefile.am: Reflect having moved automake.
mpc8260/clock/Makefile.am: Reflect having moved automake.
mpc8260/console-generic/Makefile.am: Reflect having moved automake.
mpc8260/cpm/Makefile.am: Reflect having moved automake.
mpc8260/exceptions/Makefile.am: Reflect having moved automake.
mpc8260/mmu/Makefile.am: Reflect having moved automake.
mpc8260/timer/Makefile.am: Reflect having moved automake.
mpc8xx/Makefile.am: Reflect having moved automake.
mpc8xx/clock/Makefile.am: Reflect having moved automake.
mpc8xx/console-generic/Makefile.am: Reflect having moved automake.
mpc8xx/cpm/Makefile.am: Reflect having moved automake.
mpc8xx/exceptions/Makefile.am: Reflect having moved automake.
mpc8xx/mmu/Makefile.am: Reflect having moved automake.
mpc8xx/timer/Makefile.am: Reflect having moved automake.
ppc403/Makefile.am: Reflect having moved automake.
ppc403/clock/Makefile.am: Reflect having moved automake.
ppc403/console/Makefile.am: Reflect having moved automake.
ppc403/ictrl/Makefile.am: Reflect having moved automake.
ppc403/timer/Makefile.am: Reflect having moved automake.
ppc403/tty_drv/Makefile.am: Reflect having moved automake.
ppc403/vectors/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/include/Makefile.am: Reflect having moved automake.
shared/src/Makefile.am: Reflect having moved automake.
PR 368/filesystems
* mpc8xx/include/mpc8xx.h: Add PCMCIA registers.
* configure.ac: Remove RTEMS_CHEC_CUSTOM_BSP.
* mpc505/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/console/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/tty_drv/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/include/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/src/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/Makefile.am: Merge-in mpc8260/include/Makefile.am.
* mpc8xx/Makefile.am: Merge-in mpc8xx/include/Makefile.am.
* mpc8260/include/Makefile.am: Remove.
* mpc8xx/include/Makefile.am: Remove.
* configure.ac: Remove mpc8260/include/Makefile.
Remove mpc8xx/include/Makefile.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* mpc8xx/console-generic/console-generic.c, mpc8xx/cpm/dpram.c,
mpc8xx/exceptions/raw_exception.c, ppc403/clock/clock.c:
Removed warnings.
* mpc505/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/tty_drv/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/include/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/src/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/include/cpu.h: Removed.
* shared/include/Makefile.am: Reflect changes above.
* shared/include/spr.h: Include rtems/powerpc/registers.h instead of
libcpu/cpu.h.
* mpc6xx/clock/c_clock.c: Reflect changes to <rtems/score/cpu.h>.
* mpc6xx/exceptions/asm_utils.S: Ditto.
* mpc6xx/exceptions/raw_exception.c: Ditto.
* mpc6xx/mmu/mmuAsm.S: Ditto.
* mpc6xx/timer/timer.c: Ditto.
* mpc8260/exceptions/asm_utils.S: Ditto.
* mpc8260/exceptions/raw_exception.c: Ditto.
* mpc8xx/exceptions/asm_utils.S: Ditto.
* mpc8xx/exceptions/raw_exception.c: Ditto.
* ppc403/vectors/vectors.S: Include <asm.h> instead of "asm.h".
* shared/include/cpu.h: Added ifndef ASM.
* console-generic/console-generic.c: Remove unused variable "res".
* Closed PR57. The hack is OK as it allows a BSP to override
or not at its discretion.
* mpc8xx/timer/timer.c: Removed #warning declaring providing a
default definition for the macros
rtems_cpu_configuration_get_timer_least_valid and
rtems_cpu_configuration_get_timer_average_overhead.
* mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/c_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/mmu/bat.h: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/cpm/brg.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8xx/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/include/cpuIdent.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8xx/timer/timer.c: Added hack for two macros that are not defined
with the new exception processing model:
rtems_cpu_configuration_get_timer_least_valid()
rtems_cpu_configuration_get_timer_average_overhead()
This is captured as PR57.
* mpc8260/exceptions/Makefile.am, mpc8260/include/Makefile.am,
mpc8xx/exceptions/Makefile.am: Updated to autoconf 2.52.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* mpc8xx/console-generic/console-generic.c: Bug found by Yacine
<elkolli@crf.canon.fr> where the initialization or irq data structure
was incomplete in case a SMC channel was used first and later a SCC one.
* mpc8xx/vectors/.cvsignore, mpc8xx/vectors/Makefile.am,
mpc8xx/vectors/README, mpc8xx/vectors/align_h.S
mpc8xx/vectors/vectors.S: These files were removed in
support of switching the mpc8xx to the use the "new exception
processing model."
* mpc8xx/exceptions/.cvsignore, mpc8xx/exceptions/Makefile.am,
mpc8xx/exceptions/asm_utils.S, mpc8xx/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.h: New files.
* configure.in, mpc6xx/mmu/bat.h, mpc8xx/Makefile.am,
mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
new_exception_processing/cpu.h, shared/include/byteorder.h,
wrapup/Makefile.am: This is conversion of the
mpc8xx CPU to the "new exception processing model."
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* mpc8xx/console-generic/console-generic.c: Avoid use of
BSP definitions and rely on the new routine
mbx8xx_console_get_configuration() to get information. This
routine was formerly incorrectly called
mbx8xx_console_use_maximum_buffer_size().
binding to the exception code.
* mpc8xx/console-generic/console-generic.c: Removed include of
<bsp.h> by adding BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() which can be hard coded
or check non-volatile memory for configuration.
* mpc8xx/console-generic/console-generic.c: Removed warnings.
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
Add support for configuration parameters in NVRAM
* console-generic/console-generic.c: Addition of support for shared
printk and no termios.
2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* console-generic/console-generic.c(m8xx_uart_pollWrite):
Flush actual buffer.
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
mpc8xx libcpu support for the first time and remove includes
of bsp.h, references to BSP_Configuration, and Cpu_table. All
of these can be obtained directly from RTEMS now.
significant things:
and PowerPC
same code base.
