Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
This is a preparation to remove the Giant lock.
Update #2555.
fix warning
close #2211
output.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* mpc8260/console-generic/console-generic.c,
mpc8xx/console-generic/console-generic.c:
Eliminate unused var "nb_overflow".
* e500/mmu/mmu.c, mpc505/ictrl/ictrl.c, mpc505/timer/timer.c,
mpc5xx/ictrl/ictrl.c, mpc5xx/timer/timer.c,
mpc6xx/altivec/vec_sup.c, mpc6xx/clock/c_clock.c,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/pte121.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, new-exceptions/cpu.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
ppc403/clock/clock.c, ppc403/console/console.c,
ppc403/console/console.c.polled, ppc403/console/console405.c,
ppc403/irq/ictrl.c, ppc403/tty_drv/tty_drv.c,
rtems/powerpc/cache.h, shared/include/powerpc-utility.h, shared/src/cache.c:
* mpc5xx/clock/clock.c, mpc6xx/clock/c_clock.c, mpc8260/clock/clock.c,
mpc8xx/clock/clock.c, ppc403/clock/clock.c, ppc403/clock/clock_4xx.c:
The Shared Memory Driver no longer requires the special IOCTL in
Clock_control. This was a hack which has existed since before the
Classic API Timer Manager was implemented. All implementations of and
references to Clock_control were removed.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c, mpc6xx/timer/timer.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, ppc403/timer/timer.c:
Rename timer driver methods to follow RTEMS programming conventions.
mpc8xx/console-generic/console-generic.c: Remove all references to
console_reserve_resources and termios_reserve_resources.
* mpc5xx/console-generic/console-generic.c, mpc5xx/include/console.h,
mpc8260/console-generic/console-generic.c, mpc8260/include/console.h,
mpc8xx/console-generic/console-generic.c, mpc8xx/include/console.h:
Remove all references to console_reserve_resources and
* mpc5xx/console-generic/console-generic.c, mpc8260/timer/timer.c,
new-exceptions/cpu.c, old-exceptions/cpu.c: Move interrupt_stack_size
field from CPU Table to Configuration Table. Eliminate CPU Table from
all ports. Delete references to CPU Table in all forms.
* mpc5xx/clock/clock.c, mpc5xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/cpm/brg.c, mpc8260/timer/timer.c, mpc8xx/clock/clock.c,
mpc8xx/console-generic/console-generic.c, mpc8xx/timer/timer.c,
new-exceptions/raw_exception.c, old-exceptions/cpu.c,
ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c: Eliminate PowerPC specific elements from
the CPU Table. They have been replaced with variables named bsp_XXX
as needed.
PR 1257/bsps
* mpc5xx/exceptions/raw_exception.c, mpc5xx/irq/irq.c,
mpc6xx/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c, new-exceptions/raw_exception.c,
ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c: Code outside of cpukit
should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* mpc8260/cpm/dpram.c, mpc8260/timer/timer.c, mpc8xx/cpm/dpram.c:
Remove warnings.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc8260/console-generic/console-generic.c: add parameter to new
exception interrupt handlers in powerpc bsps
* mpc8260/mmu/mmu.c: Use _CPU_MSR_GET instead of _CPU_MSR_Value.
(Unify old/new-exception processing API).
* mpc8260/cpm/dpram.c, mpc8xx/cpm/dpram.c:
Remove local rtems_panic, use #include <rtems/error.h>.
* mpc505/Makefile.am, mpc5xx/Makefile.am, mpc6xx/Makefile.am,
mpc8260/Makefile.am, mpc8xx/Makefile.am, ppc403/Makefile.am,
shared/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
shared/Makefile.am: Remove build-variant support.
* mpc505/ictrl/ictrl.c, mpc505/vectors/vectors.S,
mpc8xx/exceptions/raw_exception.c, rtems/powerpc/cache.h,
mpc5xx/ictrl/ictrl.c, mpc5xx/exceptions/raw_exception.c: Include
<rtems/score/powerpc.h> instead of <rtems/score/ppc.h>.
* mpc505/vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* mpc6xx/exceptions/asm_utils.S: Include <rtems/asm.h> instead of <asm.h>.
* mpc6xx/mmu/mmuAsm.S: Include <rtems/asm.h> instead of <asm.h>.
* mpc8260/exceptions/asm_utils.S: Include <rtems/asm.h> instead of <asm.h>.
* mpc8xx/exceptions/asm_utils.S: Include <rtems/asm.h> instead of <asm.h>.
* ppc403/vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* mpc5xx/exceptions/asm_utils.S: Include <rtems/asm.h> instead of <asm.h>.
* mpc8260/clock/clock.c: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* mpc8xx/clock/clock.c: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* ppc403/clock/clock.c: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
mpc6xx/clock/c_clock.c, mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/include/cpm.h, mpc8260/include/mmu.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/cpm/cp.c, mpc8xx/cpm/dpram.c, mpc8xx/include/cpm.h,
mpc8xx/include/mmu.h, mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c, ppc403/console/console405.c,
ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c, rtems/powerpc/cache.h, shared/src/cache.c:
Convert to using c99 fixed size types.
* mpc505/Makefile.am, mpc6xx/Makefile.am, mpc8260/Makefile.am,
mpc8xx/Makefile.am, ppc403/Makefile.am: Don't include .../lib.am.
* configure.ac: Require automake >= 1.8.2.
* Makefile.am, mpc505/Makefile.am, mpc6xx/Makefile.am,
shared/Makefile.am: Use automake compilation rules.
Add PREINSTALL_DIRS.
* mpc505/Makefile.am: Ditto.
* mpc6xx/Makefile.am: Ditto.
* mpc8260/Makefile.am: Ditto.
* mpc8xx/Makefile.am: Ditto.
* ppc403/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* mpc8260/clock/Makefile.am: Remove.
* mpc8260/console-generic/Makefile.am: Remove.
* mpc8260/cpm/Makefile.am: Remove.
* mpc8260/exceptions/Makefile.am: Remove.
* mpc8260/mmu/Makefile.am: Remove.
* mpc8260/timer/Makefile.am: Remove.
* mpc8260/Makefile.am: Merge-in Makefile.ams above.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc505/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/clock/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/mmu/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/tty_drv/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/include/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/src/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc505/ictrl/Makefile.am: Remove all-local: $(ARCH).
* mpc505/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc505/vectors/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/wrapup/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/console-generic/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/cpm/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/console-generic/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/cpm/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/timer/Makefile.am: Remove all-local: $(ARCH).
* ppc403/clock/Makefile.am: Remove all-local: $(ARCH).
* ppc403/console/Makefile.am: Remove all-local: $(ARCH).
* ppc403/ictrl/Makefile.am: Remove all-local: $(ARCH).
* ppc403/timer/Makefile.am: Remove all-local: $(ARCH).
* ppc403/tty_drv/Makefile.am: Remove all-local: $(ARCH).
* ppc403/vectors/Makefile.am: Remove all-local: $(ARCH).
* shared/include/Makefile.am: Remove all-local: $(ARCH).
* shared/src/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/Makefile.am: Reformat.
* mpc505/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/timer/Makefile.am: Reformat.
* mpc505/vectors/Makefile.am: Reformat.
* mpc6xx/Makefile.am: Reformat.
* mpc6xx/clock/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/mmu/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/timer/Makefile.am: Reformat.
* mpc6xx/wrapup/Makefile.am: Reformat.
* mpc8260/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/clock/Makefile.am: Reformat.
* mpc8260/console-generic/Makefile.am: Reformat.
* mpc8260/cpm/Makefile.am: Reformat.
* mpc8260/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/mmu/Makefile.am: Reformat.
* mpc8260/timer/Makefile.am: Reformat.
* mpc8xx/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/clock/Makefile.am: Reformat.
* mpc8xx/console-generic/Makefile.am: Reformat.
* mpc8xx/cpm/Makefile.am: Reformat.
* mpc8xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/mmu/Makefile.am: Reformat.
* mpc8xx/timer/Makefile.am: Reformat.
* ppc403/Makefile.am: Reformat.
* ppc403/clock/Makefile.am: Reformat.
* ppc403/console/Makefile.am: Reformat.
* ppc403/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/timer/Makefile.am: Reformat.
* ppc403/tty_drv/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/vectors/Makefile.am: Reformat.
* shared/Makefile.am: Reformat.
* shared/include/Makefile.am: Reformat. Use dirstamp for preinstallation.
* shared/src/Makefile.am: Reformat. Use dirstamp for preinstallation.
* wrapup/Makefile.am: Reformat.
mpc6xx/exceptions/raw_exception.c, mpc6xx/exceptions/raw_exception.h,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/brg.c,
mpc8260/exceptions/raw_exception.h, mpc8260/include/cpm.h,
mpc8260/include/mmu.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.h,
mpc8xx/include/cpm.h, mpc8xx/include/mmu.h, mpc8xx/mmu/mmu.c,
ppc403/console/console.c.polled, ppc403/timer/timer.c,
rtems/powerpc/debugmod.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: URL for license
changed.
* mpc8260/clock/clock.c: Correct copyright statements.
mpc505/Makefile.am: Reflect having moved automake.
mpc505/ictrl/Makefile.am: Reflect having moved automake.
mpc505/timer/Makefile.am: Reflect having moved automake.
mpc505/vectors/Makefile.am: Reflect having moved automake.
mpc6xx/Makefile.am: Reflect having moved automake.
mpc6xx/clock/Makefile.am: Reflect having moved automake.
mpc6xx/exceptions/Makefile.am: Reflect having moved automake.
mpc6xx/mmu/Makefile.am: Reflect having moved automake.
mpc6xx/timer/Makefile.am: Reflect having moved automake.
mpc6xx/wrapup/Makefile.am: Reflect having moved automake.
mpc8260/Makefile.am: Reflect having moved automake.
mpc8260/clock/Makefile.am: Reflect having moved automake.
mpc8260/console-generic/Makefile.am: Reflect having moved automake.
mpc8260/cpm/Makefile.am: Reflect having moved automake.
mpc8260/exceptions/Makefile.am: Reflect having moved automake.
mpc8260/mmu/Makefile.am: Reflect having moved automake.
mpc8260/timer/Makefile.am: Reflect having moved automake.
mpc8xx/Makefile.am: Reflect having moved automake.
mpc8xx/clock/Makefile.am: Reflect having moved automake.
mpc8xx/console-generic/Makefile.am: Reflect having moved automake.
mpc8xx/cpm/Makefile.am: Reflect having moved automake.
mpc8xx/exceptions/Makefile.am: Reflect having moved automake.
mpc8xx/mmu/Makefile.am: Reflect having moved automake.
mpc8xx/timer/Makefile.am: Reflect having moved automake.
ppc403/Makefile.am: Reflect having moved automake.
ppc403/clock/Makefile.am: Reflect having moved automake.
ppc403/console/Makefile.am: Reflect having moved automake.
ppc403/ictrl/Makefile.am: Reflect having moved automake.
ppc403/timer/Makefile.am: Reflect having moved automake.
ppc403/tty_drv/Makefile.am: Reflect having moved automake.
ppc403/vectors/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/include/Makefile.am: Reflect having moved automake.
shared/src/Makefile.am: Reflect having moved automake.
* configure.ac: Remove RTEMS_CHEC_CUSTOM_BSP.
* mpc505/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/console/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/tty_drv/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/include/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/src/Makefile.am: Don't include @RTEMS_BSP@.cfg.
