Also cleanup:
* Remove un-needed interrupt disables.
* Address errata "e989: FLASH: Disable Prefetch during programming and erase"
* Use RTEMS_ARRAY_SIZE() macro instead of own macro.
This partially reverts commit 1215fd4d9426a59d568560e9a485628560363133.
In order to support profiling of SMP locks and provide a future
compatible SMP locks API it is necessary to add an SMP lock destroy
function. Since the commit above adds an SMP lock to each chain control
we would have to add a rtems_chain_destroy() function as well. This
complicates the chain usage dramatically. Thus revert the patch above.
A global SMP lock for all chains is used to implement the protected
chain operations.
Advantages:
* The SAPI chain API is now identical on SMP and non-SMP
configurations.
* The size of the chain control is reduced and is then equal to the
Score chains.
* The protected chain operations work correctly on SMP.
Disadvantage:
* Applications using many different chains and the protected operations
may notice lock contention.
The chain control size drop is a huge benefit (SAPI chain controls are
66% larger than the Score chain controls). The only disadvantage is not
really a problem since these applications can use specific interrupt
locks and unprotected chain operations to avoid this issue.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Add ISR lock to chain control for proper SMP protection. Replace
rtems_chain_extract() with rtems_chain_explicit_extract() and
rtems_chain_insert() with rtems_chain_explicit_insert() on SMP
configurations. Use rtems_chain_explicit_extract() and
rtems_chain_explicit_insert() to provide SMP support.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Use mpc55xx_wait_for_interrupt().
Add defines MPC55XX_HAS_SIU and MPC55XX_HAS_SIU_LITE.
Rework of the start sequence to reduce the amount assembler code and to
support configuration tables which may be provided by the application.
* new-exceptions/bspsupport/ppc_exc_async_normal.S: Bugfix for
MPC5674F. Use it for all to be safe.
* mpc55xx/include/emios.h: Fixed eMIOS module count.
* mpc55xx/include/irq.h: Fixed CAN vector numbers.
BSP_INTERRUPT_HANDLER_TABLE_SIZE is now a BSP option.
* mpc55xx/include/fsl-mpc567x.h: Added EQADC as an alias to EQADC_A.
PR 1928/bsps:
* mpc55xx/include/fsl-mpc567x.h: Revert previous change.
* mpc55xx/misc/flash_support.c: Enable this file only for MPC55XX.
PR 1928/bsps:
* mpc55xx/include/fsl-mpc567x.h (struct FLASH_tag): Extend SIZE to 4
bits.
* mpc55xx/include/fsl-mpc567x.h: Added FLASH as an alias to FLASH_A.
* mpc55xx/include/fsl-mpc551x.h: Use legacy register naming.
* mpc55xx/include/fsl-mpc551x.h, mpc55xx/include/fsl-mpc556x.h,
mpc55xx/include/fsl-mpc567x.h: Added missing FLASH types.
* mpc55xx/include/fsl-mpc551x.h, mpc55xx/include/fsl-mpc555x.h,
mpc55xx/include/fsl-mpc556x.h, mpc55xx/include/fsl-mpc567x.h,
mpc55xx/include/regs-edma.h, mpc55xx/include/regs-mmu.h: New files.
* Makefile.am, M preinstall.am: Reflect changes above.
* mpc55xx/dspi/dspi.c: Update due to API changes.
* mpc55xx/include/edma.h, mpc55xx/edma/edma.c: Rework to support
multiple eDMA modules. Removed complex error interrupt handling.
* mpc55xx/include/esci.h, mpc55xx/esci/esci.c: Support interrupt mode
and printk(). Use configure options.
* mpc55xx/include/irq.h: More defines. API changes.
* mpc55xx/include/mpc55xx.h: API changes.
* mpc55xx/include/reg-defs.h: Added register defines.
* mpc55xx/include/regs.h: Use new register header files.
* mpc55xx/include/siu.h: Fixed includes.
* mpc55xx/misc/fmpll.S, mpc55xx/misc/copy.S, mpc55xx/misc/flash.S:
Changed sections. API changes. Support MPC5674F.
* mpc55xx/misc/flash_support.c: New file.
* Makefile.am: Reflect change above.
* mpc55xx/include/mpc55xx.h: Add definitions for the FLASH interface
and two memory protect interfaces. Add modifications to eliminate
warnings in some of the cache macros.
* mpc55xx/include/regs.h: Add some structure tag names for some
structures that I needed access to. Don't define the ALTCADR for the
MPC5554 - it is reserved and acess casues an exception. Hide the C99
designated initializers when compiling with C++. Add some support for
the EQADC.
* mpc55xx/include/esci.h, mpc55xx/include/watchdog.h: Add C++
protection.
* mpc55xx/include/mpc55xx.h, mpc55xx/misc/copy.S: Removed zero
functions.
