* mpc8260/console-generic/console-generic.c,
mpc8xx/console-generic/console-generic.c:
Eliminate unused var "nb_overflow".
* shared/include/cpuIdent.c, shared/include/cpuIdent.h
(get_ppc_cpu_type_name): Return const char*.
PR 1927/bsps:
* mpc83xx/network/tsec.c: Fixed integer truncation.
* new-exceptions/bspsupport/ppc_exc_async_normal.S: Bugfix for
MPC5674F. Use it for all to be safe.
* mpc55xx/include/emios.h: Fixed eMIOS module count.
* mpc55xx/include/irq.h: Fixed CAN vector numbers.
BSP_INTERRUPT_HANDLER_TABLE_SIZE is now a BSP option.
* mpc55xx/include/fsl-mpc567x.h: Added EQADC as an alias to EQADC_A.
PR 1928/bsps:
* mpc55xx/include/fsl-mpc567x.h: Revert previous change.
* mpc55xx/misc/flash_support.c: Enable this file only for MPC55XX.
* ppc403/clock/clock.c (ClockOn): Define pvr only for "ifndef ppc405".
* ppc403/clock/clock.c (Install_clock): Remove unused var "pvr".
* new-exceptions/bspsupport/ppc_exc_prologue.c
(ppc_exc_create_branch_op): Comment out unused var "BRANCH_OP_LINK".
* mpc5xx/clock/clock.c: Make BSP_disconnect_clock_handler decl a
prototype.
PR 1928/bsps:
* mpc55xx/include/fsl-mpc567x.h (struct FLASH_tag): Extend SIZE to 4
bits.
* mpc83xx/include/mpc83xx.h, mpc83xx/network/tsec.c: Update due to API
changes.
* mpc55xx/include/fsl-mpc567x.h: Added FLASH as an alias to FLASH_A.
* mpc55xx/include/fsl-mpc551x.h: Use legacy register naming.
* mpc55xx/include/fsl-mpc551x.h, mpc55xx/include/fsl-mpc556x.h,
mpc55xx/include/fsl-mpc567x.h: Added missing FLASH types.
* mpc55xx/include/fsl-mpc551x.h, mpc55xx/include/fsl-mpc555x.h,
mpc55xx/include/fsl-mpc556x.h, mpc55xx/include/fsl-mpc567x.h,
mpc55xx/include/regs-edma.h, mpc55xx/include/regs-mmu.h: New files.
* Makefile.am, M preinstall.am: Reflect changes above.
* mpc55xx/dspi/dspi.c: Update due to API changes.
* mpc55xx/include/edma.h, mpc55xx/edma/edma.c: Rework to support
multiple eDMA modules. Removed complex error interrupt handling.
* mpc55xx/include/esci.h, mpc55xx/esci/esci.c: Support interrupt mode
and printk(). Use configure options.
* mpc55xx/include/irq.h: More defines. API changes.
* mpc55xx/include/mpc55xx.h: API changes.
* mpc55xx/include/reg-defs.h: Added register defines.
* mpc55xx/include/regs.h: Use new register header files.
* mpc55xx/include/siu.h: Fixed includes.
* mpc55xx/misc/fmpll.S, mpc55xx/misc/copy.S, mpc55xx/misc/flash.S:
Changed sections. API changes. Support MPC5674F.
* new-exceptions/bspsupport/ppc_exc_categories.c,
shared/include/cpuIdent.c, shared/include/cpuIdent.h: Support e200z7.
* mpc55xx/misc/flash_support.c: New file.
* Makefile.am: Reflect change above.
* mpc55xx/include/mpc55xx.h: Add definitions for the FLASH interface
and two memory protect interfaces. Add modifications to eliminate
warnings in some of the cache macros.
* mpc55xx/include/regs.h: Add some structure tag names for some
structures that I needed access to. Don't define the ALTCADR for the
MPC5554 - it is reserved and acess casues an exception. Hide the C99
designated initializers when compiling with C++. Add some support for
the EQADC.
* mpc55xx/include/esci.h, mpc55xx/include/watchdog.h: Add C++
protection.
* mpc6xx/clock/c_clock.c, mpc6xx/mmu/mmuAsm.S,
new-exceptions/bspsupport/ppc_exc_global_handler.c,
shared/include/cpuIdent.c, shared/src/stack.c: Update due to API
changes.
PR 1799/bsps
* new-exceptions/bspsupport/ppc_exc_async_normal.S: New file.
* new-exceptions/cpu.c, new-exceptions/cpu_asm.S,
new-exceptions/bspsupport/ppc_exc_asm_macros.h,
new-exceptions/bspsupport/ppc_exc_prologue.c,
new-exceptions/bspsupport/vectors.h: Added support for SPE.
* configure.ac, preinstall.am, Makefile.am: Added support for qoriq
BSPs.
* Makefile.am: Remove reference to non-existing file
new-exceptions/bspsupport/nest_irq_test.c.
* new-exceptions/bspsupport/ppc_exc_alignment.c: New file.
* new-exceptions/bspsupport/vectors.h: Declare
ppc_exc_alignment_handler().
* new-exceptions/cpu_asm.S: Use BSP_DATA_CACHE_ENABLED instead of
PPC_USE_DATA_CACHE.
* shared/src/cache_.h: Moved implementation from "cache.c" to here.
This avoids the function call overhead.
* shared/src/cache.c: Removed file.
* shared/src/cache_.h: Include required header file.
* shared/include/powerpc-utility.h: API changes for ppc_*_cache_*()
functions.
* shared/include/powerpc-utility.h: Added ppc_fsl_system_version*()
functions.
* shared/include/cpuIdent.h: Fixed warnings.
* mpc83xx/network/tsec.c: New default MAC configuration. Set MDIO
clock according to actual CCB frequency. Print media info only if we
have a PHY. Avoid infinite loop in media adaption.
* new-exceptions/bspsupport/vectors.h: Added defines PPC_EXC_GPR_TYPE,
PPC_EXC_GPR_SIZE, PPC_EXC_GPR_OFFSET, PPC_EXC_MINIMAL_FRAME_SIZE, and
PPC_EXC_FRAME_SIZE. Changed layout of BSP_Exception_frame.
* new-exceptions/bspsupport/vectors.h: Add extern "C" {}.
* shared/include/powerpc-utility.h: Fixed LINKER_SYMBOL() for
assembler compatibilty. Added synchronization, cache, and alternate
time base functions.
* mpc6xx/altivec/vec_sup.c, mpc6xx/mmu/bat.h:
Fix up comments having been broken in previous commit.
* e500/mmu/mmu.c, mpc505/ictrl/ictrl.c, mpc505/timer/timer.c,
mpc5xx/ictrl/ictrl.c, mpc5xx/timer/timer.c,
mpc6xx/altivec/vec_sup.c, mpc6xx/clock/c_clock.c,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/pte121.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, new-exceptions/cpu.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
ppc403/clock/clock.c, ppc403/console/console.c,
ppc403/console/console.c.polled, ppc403/console/console405.c,
ppc403/irq/ictrl.c, ppc403/tty_drv/tty_drv.c,
rtems/powerpc/cache.h, shared/include/powerpc-utility.h, shared/src/cache.c:
* new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_naked.S,
new-exceptions/bspsupport/ppc_exc_prologue.c: Branch targets are now
global for all minimal prologues. Generate branch instruction in
minimal prologues.
* e500/mmu/mmu.c: Use common defines.
* mpc5xx/exceptions/raw_exception.c, mpc5xx/exceptions/raw_exception.h,
mpc5xx/include/console.h, mpc5xx/include/mpc5xx.h, mpc5xx/irq/irq.c,
mpc5xx/irq/irq.h, mpc5xx/irq/irq_asm.S, mpc5xx/vectors/vectors.h,
mpc5xx/vectors/vectors_init.c, mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h,
mpc6xx/mmu/mmuAsm.S, new-exceptions/bspsupport/irq.c,
new-exceptions/bspsupport/irq_supp.h,
new-exceptions/bspsupport/nested_irq_test.c,
new-exceptions/bspsupport/ppc_exc_address.c,
new-exceptions/bspsupport/ppc_exc_hdl.c,
new-exceptions/bspsupport/ppc_exc_test.c,
new-exceptions/bspsupport/vectors.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: Fix typo where
license said found in found in.
* new-exceptions/bspsupport/ppc_exc_categories.c: Fixed e500
categories.
* mpc83xx/network/tsec.c, mpc83xx/network/tsec.h: Use configuration
structure instead of many function parameters. Moved board specific
initializations. Added support for interfaces without PHY access.
* new-exceptions/bspsupport/ppc_exc_categories.c: Fixed e200 machine
check category.
* Makefile.am, preinstall.am, mpc83xx/include/mpc83xx.h,
mpc83xx/network/tsec.c, mpc83xx/network/tsec.h: Make it possible to
use the TSEC driver for other systems.
* mpc83xx/include/mpc83xx.h, mpc83xx/network/tsec.c,
mpc83xx/network/tsec.h: Make it possible to use the TSEC driver for
other systems.
* mpc55xx/include/mpc55xx.h, mpc55xx/misc/copy.S: Removed zero
functions.
* shared/include/cpuIdent.c, shared/include/cpuIdent.h: Added support
for e500v2. Removed IVPR/IVOR/HWIVOR features since they are included
in Book E.
* new-exceptions/bspsupport/vectors.h,
new-exceptions/bspsupport/ppc_exc_prologue.c: Added support for
e500v2. Added exception vector defines for Book E types. Removed
e200 exception vector defines. Added e500 exception vector defines.
Unified IVOR calculation for e200 and e500 (e200z1 has hard wired
IVOR values).
* mpc83xx/i2c/mpc83xx_i2cdrv.c: Fixed interrupt flag clearing for
MPC55XX family.
* new-exceptions/bspsupport/ppc_exc.S: Comment.
* new-exceptions/bspsupport/ppc_exc_address.c: Fixed address
calculation for e200z1 core.
* mpc55xx/edma/edma.c: Use rtems_chain_first() and do not directly
access the structure.
