Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
This is a cache manager implementation header file.
Update #3254.
Avoid duplicate mips_vector_isr_handlers() declarations.
Make sure also the size is cache aligned since otherwise we may have
some overlap with the next allocation block. A cache invalidate on this
area would be fatal.
This code was only referenced for r46xx CPU models. There are
no BSPs currently in the tree with this CPU model. The r46xx
was the original target for the MIPS port and it is likely that
the code has not been used on actual hardware in many years.
All MIPS BSPs successfully built after this was removed.
Putting the duart in libcpu was very optimistic and presumptuous.
It has never been used again on another SoC and is BSP specific.
output.
not updated.
The MIPS port defines CPU_SIMPLE_VECTORED_INTERRUPTS to FALSE.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* shared/interrupts/vectorexceptions.c: Make
mips_dump_exception_frame, mips_default_exception_code_handler
static.
PR 1917/bsps
* mongoosev/duart/mg5uart.c: Modifications to add dynamic tables for
libchip serial drivers.
* au1x00/vectorisrs/vectorisrs.c:
* mongoosev/duart/mg5uart.c: Fix type mismatch.
* au1x00/include/au1x00.h: Add prototypes for
mips_default_isr, assert_sw_irq, negate_sw_irq.
* au1x00/vectorisrs/vectorisrs.c: Remove prototype of
mips_default_isr.
* mongoosev/duart/mg5uart.c: Remove warnings.
* Makefile.am: Add shared/interrupts/isr_entries.h.
* shared/interrupts/isr_entries.h: New.
* shared/interrupts/installisrentries.c: Remove nested externs.
* mongoosev/duart/mg5uart.c: Reflect termios_baud_to_number having
been renamed to rtems_termios_baud_to_number.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* timer/timer.c: Convert to "bool".
