* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 2 | -8/+12 |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | ||||
* | Fixed paths to include files so this will build. | Joel Sherrill | 1999-03-31 | 2 | -6/+6 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 2 | -2/+2 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 2 | -4/+4 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 2 | -10/+10 |
* | commented out sccs_id's to eliminate warnings. | Joel Sherrill | 1997-04-07 | 2 | -6/+14 |
* | added $ string to file header | Joel Sherrill | 1996-09-11 | 5 | -2/+5 |
* | added definition of EXT_INT5 | Joel Sherrill | 1996-09-08 | 1 | -1/+1 |
* | removed need for exceptbdr.h file | Joel Sherrill | 1996-09-06 | 1 | -1/+1 |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 5 | -0/+483 |
Derrick Ostertag (ostertag@transition.com). |
