2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 2 | -6/+0 | |
2012-05-03 | General - Remove extraneous blank line in license message | Joel Sherrill | 1 | -1/+0 | |
Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | |||||
2012-04-04 | PR 1993 - Convert MIPS to PIC IRQ model | Jennifer Averett | 17 | -647/+205 | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | 1 | -8/+0 | |
2011-12-10 | 2011-12-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+8 | |
* shared/interrupts/vectorexceptions.c: Make mips_dump_exception_frame, mips_default_exception_code_handler static. | |||||
2011-10-18 | 2011-10-18 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2 | -35/+41 | |
PR 1917/bsps * mongoosev/duart/mg5uart.c: Modifications to add dynamic tables for libchip serial drivers. | |||||
2011-02-11 | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+6 | |
* au1x00/vectorisrs/vectorisrs.c: Use "__asm__" instead of "asm" for improved c99-compliance. | |||||
2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||||
2011-01-30 | 2011-01-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* mongoosev/duart/mg5uart.c: Fix type mismatch. | |||||
2010-05-28 | 2010-05-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -1/+16 | |
* au1x00/include/au1x00.h: Add prototypes for mips_default_isr, assert_sw_irq, negate_sw_irq. * au1x00/vectorisrs/vectorisrs.c: Remove prototype of mips_default_isr. | |||||
2010-04-28 | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2 | -7/+9 | |
* mongoosev/duart/mg5uart.c: Remove warnings. | |||||
2009-11-30 | Whitespace removal. | Ralf Corsepius | 20 | -90/+90 | |
2009-11-28 | Whitespace removal. | Ralf Corsepius | 1 | -1/+1 | |
2009-11-16 | Regenerate. | Ralf Corsepius | 1 | -0/+4 | |
2009-11-16 | 2009-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+3 | |
* Makefile.am: Add shared/interrupts/isr_entries.h. | |||||
2009-11-16 | 2009-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* shared/interrupts/isr_entries.h: New. | |||||
2009-11-16 | New. | Ralf Corsepius | 1 | -0/+26 | |
2009-11-16 | 2009-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* shared/interrupts/installisrentries.c: Remove nested externs. | |||||
2009-11-16 | Remove nested externs. | Ralf Corsepius | 1 | -14/+2 | |
2009-09-30 | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* mongoosev/duart/mg5uart.c: Reflect termios_baud_to_number having been renamed to rtems_termios_baud_to_number. | |||||
2009-09-30 | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
2008-09-30 | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -4/+8 | |
* timer/timer.c: Eliminate uses of old benchmark timer names. | |||||
2008-09-05 | 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2 | -33/+7 | |
* clock/ckinit.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed. | |||||
2008-09-05 | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* timer/timer.c: Convert to "bool". | |||||
2008-09-05 | Convert to "bool". | Ralf Corsepius | 1 | -4/+2 | |
2008-08-31 | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -19/+14 | |
* timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | |||||
2008-07-14 | Cleanup. | Ralf Corsepius | 1 | -6/+0 | |
2007-11-26 | 2007-11-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -8/+9 | |
* clock/ckinit.c: Eliminate the clicks_per_microsecond field in the MIPS CPU Table and define another mechanism for drivers to obtain this information. | |||||
2007-03-12 | 2007-03-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -3/+10 | |
* au1x00/include/au1x00.h, au1x00/vectorisrs/maxvectors.c, au1x00/vectorisrs/vectorisrs.c: Correct license URL and/or fix mistake in copyright notice. Both of these mistakes appear to be from code submitted after these changes were made previously. | |||||
2007-01-08 | Regenerate. | Ralf Corsepius | 1 | -2/+2 | |
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-10-19 | 2006-10-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -3/+7 | |
* mongoosev/duart/mg5uart.c: Change type to unsigned. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2006-09-14 | 2006-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+9 | |
* mongoosev/duart/mg5uart.c: Removed warnings. | |||||
2006-09-11 | 2006-09-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -47/+50 | |
* mongoosev/vectorisrs/vectorisrs.c: Convert C++ style comments to C style. | |||||
2006-06-08 | B.Robinson MIPS patch | Greg Menke | 4 | -12/+44 | |
2006-05-16 | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -3/+5 | |
* configure.ac: Use RTEMS_AMPOLISH3. | |||||
2006-04-02 | 2006-04-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Remove bogus CFLAGS_OPTIMIZE_V. | |||||
2006-03-17 | 2006-03-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -6/+17 | |
* shared/interrupts/vectorexceptions.c: Merger with submission from Bruce Robinson <brucer@pmccorp.com>. Make some arrays static const. | |||||
2006-03-16 | Regenerate. | Ralf Corsepius | 1 | -0/+14 | |
2006-03-16 | Cosmetics. | Ralf Corsepius | 1 | -8/+0 | |
2006-03-16 | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -0/+46 | |
* Makefile.am, configure.ac: Reflect addition of rm52xx, tx49. | |||||
2006-03-16 | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+8 | |
* rm52xx/include/rm5231.h, rm52xx/vectorisrs/maxvectors.c, rm52xx/vectorisrs/vectorisrs.c, tx49/include/tx4925.h, tx49/include/tx4938.h, tx49/vectorisrs/maxvectors.c, tx49/vectorisrs/vectorisrs.c: New (Submission by Bruce Robinson <brucer@pmccorp.com>). | |||||
2006-03-16 | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 7 | -0/+543 | |
2006-01-14 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -0/+2 | |
2006-01-12 | Remove all-local:. | Ralf Corsepius | 1 | -2/+0 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -2/+2 | |
2006-01-12 | Cleanup. | Ralf Corsepius | 1 | -3/+0 | |
2005-11-07 | Fixed formatting. | Joel Sherrill | 1 | -2/+2 | |
