that contains:
* Removes MKLIB
handling)
converted to automake.
of the mask when disabling the interrupt.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
./bootstrap
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
BSP needs to be eliminated.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
Derrick Ostertag (ostertag@transition.com).
