* | Removed CONFIG_DIR and PROJECT_HOME directories. | Joel Sherrill | 1998-01-20 | 4 | -4/+4 |
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 4 | -4/+16 |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | ||||
* | Fixed incorrect reference to RTEMS_BSP instead of RTEMS_BSP_FAMILY. | Joel Sherrill | 1997-10-09 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 2 | -4/+4 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 2 | -10/+10 |
* | commented out sccs_id's to eliminate warnings. | Joel Sherrill | 1997-04-07 | 2 | -6/+14 |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 4 | -0/+151 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | added $ string to file header | Joel Sherrill | 1996-09-11 | 5 | -2/+5 |
* | added definition of EXT_INT5 | Joel Sherrill | 1996-09-08 | 1 | -1/+1 |
* | removed need for exceptbdr.h file | Joel Sherrill | 1996-09-06 | 1 | -1/+1 |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 5 | -0/+483 |
Derrick Ostertag (ostertag@transition.com). |
