* mongoosev/Makefile.am: Rework preinstall rules.
* mongoosev/duart/Makefile.am: Rework preinstall rules.
* tx39/include/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in tx39/include/Makefile.am.
* configure.ac: Remove tx39/include/Makefile.
mongoosev/Makefile.am: Reflect having moved automake.
mongoosev/duart/Makefile.am: Reflect having moved automake.
mongoosev/vectorisrs/Makefile.am: Reflect having moved automake.
r46xx/Makefile.am: Reflect having moved automake.
r46xx/vectorisrs/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/cache/Makefile.am: Reflect having moved automake.
shared/interrupts/Makefile.am: Reflect having moved automake.
tx39/Makefile.am: Reflect having moved automake.
tx39/include/Makefile.am: Reflect having moved automake.
tx39/vectorisrs/Makefile.am: Reflect having moved automake.
* mongoosev/duart/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/interrupts/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'CLEANFILES ='.
* shared/cache/Makefile.am, tx39/include/Makefile.am:
* shared/.cvsignore, shared/Makefile.am,
shared/cache/.cvsignore, shared/cache/Makefile.am,
shared/cache/cache.c, shared/cache/cache_.h,
shared/interrupts/.cvsignore, shared/interrupts/Makefile.am,
shared/interrupts/installisrentries.c,
shared/interrupts/isr_entries.S,
shared/interrupts/maxvectors.c, tx39/.cvsignore,
tx39/Makefile.am, tx39/include/.cvsignore,
tx39/include/Makefile.am, tx39/include/tx3904.h: New file.
Moved some pieces of interrupt processing from score/cpu to
libcpu/mips since many interrupt servicing characteristics are
CPU model dependent. This patch addresses the number of interrupt
sources and where the ISR prologues are located. The only way to
currently install the ISR prologues requires that the prologues
be installed into RAM.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
