path: root/c/src/lib/libcpu/mips/tx39/include/Makefile.am (follow)
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | | | | * tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='. * mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='. * mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/cache/Makefile.am: Use 'CLEANFILES ='.
* 2001-03-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-03-051-2/+4
| | | | | * shared/cache/Makefile.am, tx39/include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2000-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-131-0/+22
* shared/.cvsignore, shared/Makefile.am, shared/cache/.cvsignore, shared/cache/Makefile.am, shared/cache/cache.c, shared/cache/cache_.h, shared/interrupts/.cvsignore, shared/interrupts/Makefile.am, shared/interrupts/installisrentries.c, shared/interrupts/isr_entries.S, shared/interrupts/maxvectors.c, tx39/.cvsignore, tx39/Makefile.am, tx39/include/.cvsignore, tx39/include/Makefile.am, tx39/include/tx3904.h: New file. Moved some pieces of interrupt processing from score/cpu to libcpu/mips since many interrupt servicing characteristics are CPU model dependent. This patch addresses the number of interrupt sources and where the ISR prologues are located. The only way to currently install the ISR prologues requires that the prologues be installed into RAM.
