* configure.ac: Use RTEMS_AMPOLISH3.
* Makefile.am, configure.ac: Reflect addition of rm52xx, tx49.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* Makefile.am: Distibute mongoosev's READMEs
* preinstall.am: New.
* Makefile.am: Merge in au1x00/Makefile.am, mongoosev/Makefile.am,
r46xx/Makefile.am, shared/Makefile.am.
Include preinstall.am.
* au1x00/Makefile.am, mongoosev/Makefile.am,
r46xx/Makefile.am, shared/Makefile.am: Remove.
* Makefile.am, configure.ac: New CPU.
* shared/interrupts/installisrentries.c,
shared/interrupts/isr_entries.S: Added CPU32 support.
* au1x00/Makefile.am, au1x00/include/au1x00.h,
au1x00/vectorisrs/maxvectors.c, au1x00/vectorisrs/vectorisrs.c: New CPU.
* configure.ac: Remove RTEMS_ENABLE_BARE.
* configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP.
* clock/Makefile.am, timer/Makefile.am: Remove.
* r46xx/Makefile.am: Built timer.rel, clock.rel.
Add PREINSTALL_DIRS.
* Makefile.am: Remove timer, clock.
* tx39/Makefile.am, mongoosev/Makefile.am, shared/Makefile.am:
* configure.ac: Reflect removing clock/Makefile.am,
timer/Makefile.am.
Add subdir-objects to AUTOMAKE_OPTIONS.
* clock/Makefile.am: Convert to using automake compilation rules.
* mongoosev/Makefile.am: Ditto.
* r46xx/Makefile.am: Ditto.
* shared/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* tx39/Makefile.am: Ditto.
* Makefile.am: Remove conditional subdirs.
* configure.ac: Add subdir-object to AUTOMAKE_OPTIONS.
Require automake-1.8.2. Add AM_PROG_CC_C_O.
* mongoosev/duart/Makefile.am: Remove.
* mongoosev/vectorisrs/Makefile.am: Remove.
* mongoosev/Makefile.am: Merge-in vectorisrs/Makefile.am,
duart/Makefile.am.
* r46xx/vectorisrs/Makefile.am: Remove.
* r46xx/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/cache/Makefile.am: Remove.
* shared/interrupts/Makefile.am: Remove.
* shared/Makefile.am: Merge-in cache/Makefile.am,
interrupts/Makefile.am.
* tx39/vectorisrs/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in vectorisrs/Makefile.am.
* mongoosev/Makefile.am: Rework preinstall rules.
* mongoosev/duart/Makefile.am: Rework preinstall rules.
* tx39/include/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in tx39/include/Makefile.am.
* configure.ac: Remove tx39/include/Makefile.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* configure.ac: Add RTEMS_PROG_CCAS.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* configure.ac: Remove duplicate timer/Makefile from CONFIG_FILES.
* mongoosev/duart/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/interrupts/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
