Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* mcf5225x/network/fec.c, mcf5235/cache/cachepd.c,
mcf532x/cache/cachepd.c, shared/cache/cache.c, shared/misc/m68kidle.c:
* Makefile.am, configure.ac, preinstall.am: Add mcf5225x support.
* mcf5225x/include/fec.h, mcf5225x/include/mcf5225x.h,
mcf5225x/network/fec.c: New files.
* shared/misc/m68kidle.c: somehow this change was never committed, sorry.
paranthesis around usage of x in some macros
* shared/misc/m68kidle.c: added "cc" clobber to inline
asm; STOP instruction modifies CCR!
* shared/misc/m68kidle.c: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
PR 1369/bsps
* Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp
floating-point emulation.
* mcf5206/timer/timerisr.S: Make compile again.
* Makefile.am: Split out various BSPs bspstart.c contents. Move cache
management code here.
* mcf5223x/cache/cachepd.c, mcf5235/cache/cachepd.c: New files.
* mcf5206/timer/timerisr.S: Remove unnecessary include of bsp.h
* mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style,
eliminate characters with 8th bit set.
* mcf548x/include/mcf548x.h: Convert to Unix file format.
* mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: The Shared Memory
Driver no longer requires the special IOCTL in Clock_control. This
was a hack which has existed since before the Classic API Timer
Manager was implemented. All implementations of and references to
Clock_control were removed.
* mcf5206/timer/timer.c, mcf5272/timer/timer.c: Convert to "bool".
* mcf5206/console/mcfuart.c, mcf5206/include/mcfuart.h:
Eliminate rtems_boolean.
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* mcf5206/timer/timer.c, mcf5206/timer/timerisr.S,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver
* m68040/fpsp/rtems_fpsp.c: Move extern outside of braces.
* shared/misc/m68kidle.c: Correct prototype of Idle threads.
