* | 2007-06-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-04 | 3 | -94/+7 | |
| | | | | | | * Makefile.am: Now use the m68k memcpy and memset recently added to newlib instead of our own. * shared/misc/memcpy.c: Removed. | |||||
* | 2007-03-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-12 | 5 | -7/+11 | |
| | | | | | | | * mcf5272/clock/ckinit.c, mcf5272/include/mcf5272.h, mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Correct license URL and/or fix mistake in copyright notice. Both of these mistakes appear to be from code submitted after these changes were made previously. | |||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -5/+5 | |
* | * m68k/mcf5282/include/mcf5282.h: added __may_alias__ | Till Straumann | 2006-12-14 | 2 | -810/+818 | |
| | | | | | attribute to low-level scalar type definitions and removed intermediate (void*) cast. | |||||
* | 2006-12-14 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2006-12-14 | 2 | -1/+6 | |
| | | | | | * m68k/mcf5282/include/mcf5282.h: fixed wrong value of MCF5282_QSPI_QDLYR_SPE. | |||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 | |
| | | | | * configure.ac: New BUG-REPORT address. | |||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 | |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
* | Remove extra CRLF. | Chris Johns | 2006-09-11 | 1 | -2/+1 | |
* | Remove extra CRLF. | Chris Johns | 2006-09-11 | 1 | -0/+5 | |
* | Remove extra CRLF. | Chris Johns | 2006-09-11 | 1 | -2399/+2399 | |
* | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-05-16 | 2 | -3/+5 | |
| | | | | * configure.ac: Use RTEMS_AMPOLISH3. | |||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 | |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 | |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 | |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -3/+0 | |
* | Regenerate. | Ralf Corsepius | 2005-07-27 | 1 | -10/+10 | |
* | 2005-07-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-27 | 2 | -1/+5 | |
| | | | | * Makefile.am: Fix broken patch to mcf5235. | |||||
* | 2005-07-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-07-08 | 2 | -7/+5 | |
| | | | | * Makefile.am: Eliminate duplicate entry for include_mcf5235... . | |||||
* | 2005-06-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-06-17 | 5 | -0/+3030 | |
| | | | | | | * ChangeLog, Makefile.am, configure.ac, preinstall.am: Addition of mcf5235 support. * mcf5235/include/mcf5235.h: New file. | |||||
* | Remove. | Ralf Corsepius | 2005-05-11 | 7 | -117/+0 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+7 | |
| | | | | | | | * Makefile.am: Merge-in mcf5282/Makefile.am. * preinstall.am: Regenerate. * mcf5282/Makefile.am: Remove. * configure.ac: Remove mcf5282/Makefile. | |||||
* | Remove mcf5282/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Merge-in mcf5282/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -3/+6 | |
* | Regenerate. | Ralf Corsepius | 2005-05-11 | 1 | -0/+10 | |
| | | | | | | | * Makefile.am: Merge-in mcf5272/Makefile.am. * preinstall.am: Regenerate. * mcf5272/Makefile.am: Remove. * configure.ac: Remove mcf5272/Makefile. | |||||
* | mcf5272/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -1/+19 | |
* | Regenerate. | Ralf Corsepius | 2005-05-11 | 1 | -0/+28 | |
* | Remove mcf5272/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
| | | | | | | | * Makefile.am: Merge-in mcf5206/Makefile.am. * preinstall.am: Regenerate. * mcf5206/Makefile.am: Remove. * configure.ac: Remove mcf5206/Makefile. | |||||
* | Remove mcf5206/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Merge-in mcf5206/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -1/+33 | |
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -70/+0 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+6 | |
| | | | | | | * Makefile.am: Merge-in m68040/Makefile.am. * m68040/Makefile.am: Remove. * configure.ac: Remove m68040/Makefile. | |||||
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -30/+0 | |
* | Remove m68040/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Merge-in m68040/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -1/+25 | |
* | Fix typo in previous patch. | Ralf Corsepius | 2005-05-11 | 1 | -1/+1 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+8 | |
| | | | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * preinstall.am: New. * shared/Makefile.am: Remove. * configure.ac: Remove shared/Makefile. Add AMPOLISH3. | |||||
* | Remove shared/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+4 | |
* | Merge-in shared/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -0/+37 | |
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+24 | |
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -61/+0 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+4 | |
| | | | | * mcf5282/include/Makefile.am: Remove (unused). | |||||
* | Remove (unused). | Ralf Corsepius | 2005-05-11 | 1 | -23/+0 | |
* | 2005-04-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-04-26 | 2 | -9/+13 | |
| | | | | * mcf5206/include/mcfuart.h: Reformatted. | |||||
* | Remove development warning. | Eric Norum | 2005-02-16 | 2 | -1/+4 | |
* | Add memory probe support. | Eric Norum | 2005-02-03 | 3 | -1/+108 | |
* | 2005-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-01 | 2 | -0/+6 | |
| | | | | * mcf5282/.cvsignore: New file. | |||||
* | Add ColdFire cache information. | Eric Norum | 2005-01-31 | 2 | -5/+15 | |
* | New BSP/CPU. | Eric Norum | 2005-01-28 | 6 | -1/+2467 | |
