BSP needs to be eliminated.
to address m68k-rtemself for the MVME167.
Here is the rtems patch I promissed you a long time ago to enable ELF
with m68k. The target name I selected is m68k-rtemself. It preserves the
m68k-rtems COFF target, and is parterned after the other ELF/COFF dual
targets.
The mvme167.cfg file causes the -qelf flag to be used during compilation
if the name of the compiler contains rtemself. This flag is used in the
bsp_specs file to select the elflinkcmds file rather than the linkcmds
file. The former is for ELF, the latter for COFF.
Some patches are required to the mc68040 FPSP code. Some of the
assembler files contain instructions that were rejected by the
m68k-rtemself-as assembler. This is a minor bug in the m68k ELF
assembler, I think.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
important distinctions between CPU models which are not made by gcc.
These distinctions help give us a more optimized memcpy(). This is important
for message queues and KA9Q.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
enclose.
were a number of minor problems which had to be fixed to get it
to compile including modifying the compile rule to handle C++ comments,
changing the syntax of the include statement, and getting rid of "%"
as part of register names.
to RTEMS by Eric Norum. It is freely distributable and was acquired
from the Motorola WWW site. More info is in the FPSP README.
